Possible Steering Problem?
Old Nov 17, 2013 | 04:18 PM
BlueFox's Avatar
Question Possible Steering Problem?
whether i am rolling forward or backing up, with the wheel fully cranked (either way) i feel a shudder (Like a thud thud thud thud, and a bumping feeling) my dad seems to think it could be from having wider than normal tires?
Old Nov 17, 2013 | 05:05 PM
5litereater's Avatar
How worn are your tires?
Old Nov 22, 2013 | 07:02 AM
BlueFox's Avatar
I got plenty of treat, yesterday a buddy said it was a CV joint or something
Old Nov 22, 2013 | 03:25 PM
dcpirani's Avatar
Your car does not have CV joints. If you have a wider tire in the front, it will rub at full turn. Hope this helps.
Old Nov 22, 2013 | 03:29 PM
Check inside your tire well where the tire meets the frame if fully turned. If it's rubbing you should see evidence easily on the frame. I had this problem when I changed my steering rack. It only did it when I turned tight. The fix was some additional steering stop spacers that go on the rack at each end inside the rubber boot. They are a cheap and simple little nylon part.
Old Nov 22, 2013 | 08:52 PM
BlueFox's Avatar
Well thats good to hear, i believe they are wider than stock (someone put rims on it) and they are 17" by 8.89"... Not sure if i just round that to 9" orrr...
and I'm going to check right now to see if it rubs, thanks,i got a movie date tonight i don't want to scare her and her think the cars rattling apart
Old Nov 22, 2013 | 08:56 PM
BlueFox's Avatar
Whoops, i meant 16" by 9"
Old Nov 22, 2013 | 09:00 PM
Here's the possible fix
http://www.latemodelrestoration.com/...Limiter-6-Pack
Old Nov 23, 2013 | 12:04 PM
ALMOST STOCK's Avatar
Sounds almost like have air trapped in the in the power steering pump system.
Old Nov 23, 2013 | 12:08 PM
Those will stop the tires or rims (usually the rim on the A-arms) from rubbing. And if that's the problem here is how you install them.
http://ironhorse.activeboard.com/t40...-at-full-lock/
Rando
Aug 25, 2021 11:12 AM
ricky1728
Feb 11, 2016 07:25 PM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
Linkspure
Sep 12, 2015 06:33 PM
