oilpan removal!
Old Dec 21, 2010 | 02:58 PM
Twic's Avatar
Was wondering if anybody knows if their is enough Clearance to remove the oil pan if the rack and pinion is off the car?? Sorry! On a 1988 mustang
Old Dec 21, 2010 | 04:02 PM
Dread53's Avatar
It's been a long time since I worked on one of these, but I'm thinking not without jacking up the engine a long way. It may also require dropping the oil pump and pickup tube once the pan is dropped but prior to removing it.
Old Dec 21, 2010 | 06:17 PM
Twic's Avatar
Thanks. I forgot all about the oil pump! I'm replacing the rack and pinion and figured I would take care of an oil leak at the same time!! But I guess not!
Old Dec 21, 2010 | 06:21 PM
I replaced the rack and pinion last month along with the steering shaft assembly. I also have an oil leak but mine is at the rear main.
Even with the steering rack out the K-member is still there and therefore the engine would have to be jacked up like stated above. And drop the oil pump into the pan like stated above too.
Gotta say though that replacing the rack and the old rag joint steering shaft was a great improvement to the old Fox.
Old Dec 21, 2010 | 06:52 PM
Twic's Avatar
So far I have replaced everything on the front end all the way down to new bolts!! The rack and pinion and steering shaft is the last thing and the front end will be done!!
Old Dec 22, 2010 | 04:03 AM
I Take it, that it would be a major pain to remove the k member?
Old Dec 22, 2010 | 06:26 AM
Dread53's Avatar
The K-member holds in the engine, so you'd need a sling brace between the fenders to hang the engine. Now, if my memory serves (which is getting tough for this old fart) the pan gasket is a rubber one piece unit. I had good success working this into place without actually removing the pan. They had a bad habit of splitting, usually near the dipstick. I think that still required jacking the engine a bit, but much simpler than removing the pan.
2k7, make sure that oil leak isn't coming off the back of the intake manifold. I saw a lot of those that blew out the cork seal back there.
Old Dec 22, 2010 | 07:28 PM
Twic's Avatar
Pretty sure the oil leak is by the dipstick! Thanks.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
jim010
Sep 14, 2015 10:15 PM
Sep 10, 2015 12:44 PM
