is it the oil pump or distributor ?
Old Sep 25, 2013 | 06:48 PM
pricanclaudio's Avatar
I installed in my fox a pro billet distributor for my 302 carburated h/o 5.0 and I changed the stock oil pump for a high volume oil pump. Now my distributor will not stab all the way down an it sits about 3 1/16 higher than block , it as if oil rod is to long know , has anyone came across this issue before ?
Old Sep 25, 2013 | 06:56 PM
see which way the center of the bottom of your dist. points, then take a long reg screw driver and stick it in the whole that the dist plugs into and turn the oil pump deal so they line up, then try pluging the dist into said hole
Old Sep 25, 2013 | 06:59 PM
Its not like a chevy distributor the has a slot , this 302 has a rod with a hex tapered end on rod side going into distributor.
Old Sep 26, 2013 | 06:33 AM
doh how does the new dist compare to the old one side by side?
Old Sep 26, 2013 | 02:20 PM
HOSS429's Avatar
legacy Tms Member
bump the engine over a little bit with the solenoid switch while you are pushing down on the dizzy ..do not have the switch on ...
Old Sep 26, 2013 | 02:45 PM
Ok I will try that thanks again
Old Oct 5, 2013 | 08:15 AM
Spaz's Avatar
Do you have the original dist. and can you compare it to the new one to make sure they are exact matches?
Old Oct 5, 2013 | 03:26 PM
this ....well thats what I asked afew days ago. I was thinking the neck might be a little on the large size or it has a burr on it
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
Beouch
Sep 16, 2015 06:14 PM
