oil drain plug/gasket on 85 GT
Old Jul 23, 2011 | 04:45 PM
5pointoh's Avatar
I have just started to do my own oil changes and was wondering does anyone know what specifications does the oil drain plug need to be torqued to?
I just noticed that there is the occasional drip of oil coming off the oil drain plug.....and was wondering did I tighten it enough?
Also I have two Mustangs......and I think one requires a drain plug gasket and the other does not. Just want to confirm is it my 85 that needs the gasket and my 05 GT does not??
Old Aug 16, 2011 | 02:23 PM
89mustanglx's Avatar
Not super tight just snug
Old Aug 16, 2011 | 04:06 PM
houtex's Avatar
A standard, appropriately sized wrench and your arm muscles are all that's needed. Just get it to stop turning in a reasonable amount of torque... i.e., when you think it's tight, it's tight. If it leaks any, turn it 1/16th more or so. If the pan is warped, well... you probably know what to do then, although that fitting is pretty stout in there, so I doubt it's warped or such.
Can't say as to yes or no on the plug gasket though.
dblhelx
Oct 6, 2015 08:08 PM
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
