OIL???
Old Aug 15, 2012 | 06:36 PM
FORDBOY123's Avatar
OIL???
My 88 GT takes too much oil a few quarts a month anyone else have this problem
Old Aug 16, 2012 | 05:57 PM
FOX50's Avatar
Is it messy under your hood like alot of oil build up?
Old Aug 16, 2012 | 10:20 PM
FORDBOY123's Avatar
Nope it's not leaking not burning it's just gone
Old Aug 24, 2012 | 05:30 PM
Tirefryer's Avatar
Only 3 places it could be going... Leaking.... Burning.... Or into the coolant.... All are bad!!! Lol
Old Aug 25, 2012 | 08:39 PM
houtex's Avatar
Indeed a *FEW* quarts... and if you can't find the leak... it's burning the oil or it's in the coolant. Both are bad.
Check compression in the cylinders, but first and foremost, check the coolant. Could be a busted head gasket.
But really, let's say it's two quarts... that's half a quart missing per week... you *should see that* on the ground, if it's a leak. You probably should see that in the exhaust if it was burning, deposits on the tips, for example, or some smoke on takeoff...
And if you're not checking the coolant... well, you sure you have coolant and not just a bunch of oil?!
/hope you find it, seriously.
Old Aug 25, 2012 | 09:35 PM
I'm guessing valve guide seals and rings are bad. When you start it up do you see a cloud of smoke out of the exhaust, or when your your driving along and nail it do you see a cloud of smoke then??
Old Sep 3, 2012 | 08:56 PM
UOP Shadow's Avatar
My 88 GT doesn't burn any oil. What the other posters said is correct about what to check. The only thing I'd add is to check the bottom of your car behind the oil pan. It may be possible that your oil is leaking only under pressure and is all over the bottom of your car.
dblhelx
Oct 6, 2015 08:08 PM
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
