New Flywheel
Old Nov 7, 2005 | 09:15 AM
Autotooner's Avatar
My C/T is cooler than Arin is.
I believe that I need a new flywheel for my 'stang. I think, it starts really rough, and some times delays before it goes into gear. Is this what I need? How hard would it be to change it?
Old Nov 7, 2005 | 06:46 PM
Hotrod's Avatar
You might want to check your cable. Our's was acting up like that but we got to looking and the cable is frayed. As far as changing it out its just a matter of removing the driveshaft and exhaust, dropping the tranny, and removing the bell housing and clutch. If you do have to change the fly wheel I would look at the clutch and put in a new throughout bearing while I was down there.
Old Nov 7, 2005 | 06:49 PM
Autotooner's Avatar
I found out that my negative battery terminal connector thingy has been replaced and the new one don't make contact very well.
So I'm gonna get the stuff to replace that and the new carb. (choke don't work) hopefully it works.
Ecostang
Nov 3, 2022 08:50 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
