Need some help choosing an intake
Old Oct 7, 2013 | 08:51 AM
NoHandles13's Avatar
Hey guys doing a pretty small build, currently have comp cam xe264hr-14 with some flotek heads180 runners and 58cc chambers was wondering what intake I should use building a prettt much street car that occasionally see the strip oh and im stayinf efi any help would be appriciated
cars an 1987 5.0l with maf upgrade from an 89 full exhuast aluminum drive shaft 373 and a cold air
Old Oct 8, 2013 | 10:53 AM
LivinTheStangLife's Avatar
trick flow has some BA intakes for the 5.0L, might wanna check them out
Old Oct 9, 2013 | 07:48 AM
MustangFrontier's Avatar
Explorer intake is best bang for buck.
Old Oct 9, 2013 | 10:03 AM
How does it compare to the cobra intake ?
Old Oct 9, 2013 | 10:34 AM
i think it flows better imo and looks cooler under the hood. i have the trick flow street burner or track heat on mine with a 1" spacer for valve cover clearance bc i have the tall trick flow valve covers and either 70 or 75mm tb. not for sure which one it is as unfortunately i didn't build my 95 i bought it build bc i got a good deal on it. i also have the cobra hood on mine i think there wasn't enough clearance with stock hood with the spacer. i just looked it up though street burner has longer runners for better low end torque and track heat has shorter runners for more high end torque. i know a couple people who've got the cobra intake as well but theirs isn't quite as built as mine.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
RoushRS3
Sep 29, 2015 08:03 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
