need help RE:fuel pump
Old Jun 13, 2007 | 07:40 PM
grd777's Avatar
had a few problems lately ,car did not start last week after i left the pup and tonite .it started but but shut down after a few miles.treid to start it seems to start but will not fire up ,is it the fuel pump
Old Jun 13, 2007 | 08:21 PM
grd777's Avatar
updat .got car towed home .let it cool down started right away ,what do you guys thinks
Old Jun 14, 2007 | 02:40 PM
eci's Avatar
eci
Check TFI module.
Do you hear the fuel pump prime when you turn the ignition on?
Old Jun 14, 2007 | 05:04 PM
grd777's Avatar
still need help on this one guys
Originally Posted by eci
Check TFI module.
yes i hear the fuel pump prime . how can i check the tfi module
Old Jun 19, 2007 | 12:07 PM
jacostang's Avatar
If it was the module it would most likely be out completly. Does it crank and not start up?
Old Jun 19, 2007 | 12:11 PM
jacostang's Avatar
The pump could be going out, mine did that for about 10 miles but it got me home. What year car do you have and do ya know how old the pump is???
Old Jun 19, 2007 | 12:14 PM
eci's Avatar
eci
The TFI module is known to quit when hot, and work perfectly once cooled off. There was actually a class action lawsuit about this a few years back.
http://www.coolcats.net/tech/troubleshooting/tfi.html
Old Jun 19, 2007 | 06:56 PM
lp9820's Avatar
i think i'm in the same position as you
my 86' wont start any more after giving me a few months of trouble and now my pump is out completly
Old Jun 24, 2007 | 04:39 PM
DavidM's Avatar
It's the fuel pump. I had the exact same problem twice over the 8-10 fox cars that I have owned. Be sure to replace the filter when you do the pump. Also a cheap alternative to an aftermarket one is to go to the parts store and get one for a 93 cobra. The pumps in these were rated at a higher flow to push the 24 lb. injectors that came stock on that year. If your stock. If not then a good aftermarket one will do the trick.
Sep 16, 2015 06:44 PM
Beouch
Sep 16, 2015 06:14 PM
eastexsteve
Aug 17, 2015 12:07 PM
retiredf5
Ecoboost
Jul 21, 2015 05:54 PM
