Need Help With Install Of Bbk Ssi Lower Intake On My 88 Fox 302
Old Mar 31, 2014 | 01:33 PM
timeball's Avatar
Hi I just have a few quick questions on this install and some of this community imput on my setup. I just dropped in some aluminum gt 40x heads with some crane cam 1.7 ped mount roller rockers. i am already runing a ford racing f 303 cam. heads are on and torqued down to spec. so I just finished puttinuig together the fuel rails and injectors on the lower and ready to install it to the heads. I notcied the hardware kit that came with the intake does not have the lower mounting bolts. Should I just use the old ones with these heads? Or should I order new ones? If so what should I order.? And I also have another question regarding my the injectors. I am installing 30 lbs injectors with a 73mm cailibrated MAF will this be to much fuel for my set up? Thanks
Old May 9, 2014 | 07:38 AM
bluefox88's Avatar
not sure how guys match mass air/injectors, but I can tell you Im running ssi intake, I reused my old bolts, there fine just clean em up good! also when u torque ur lower, if not already informed make sure after u torque in 3 stages, go back and re-due "multiple" times till you can go back to center and bolt dose not move
Ecostang
Nov 3, 2022 08:50 PM
Jtm90fox
May 22, 2016 01:55 PM
tdf017
Aug 5, 2015 10:13 AM
