Mustang Shut Off When Driving
Old Nov 11, 2013 | 05:45 PM
5litereater's Avatar
Hey guys! I have a 93 2.3 na. So I was driving down my street coming home from my dads and it just died... I pulled over and tried cranking it for about 30-45min nothing. So I left it there for about 5hrs walked home n came back and she started right up. But it seemed to have a small miss and it staggered when I accelerated. As soon as I got home it died again. Had to push it up the drive way lol. Any answers?
Old Nov 11, 2013 | 05:50 PM
Also I've replaced the fuel pump, fuel filter, fuel pressure regulator, spark plugs, spark plug wires, maf, coolant temp sensor, water pump, coils, and the ICM.
Old Nov 11, 2013 | 06:48 PM
southcarolina12's Avatar
replaced all of that since it messed up? not sure what type of fuel injection system those have but it sounds like a ignition problem. if its a spider injection setup it could be low fuel pressure.
Old Nov 14, 2013 | 02:27 PM
Replaced before hand and yea I think so too
Old Nov 15, 2013 | 08:17 AM
KingKoupe's Avatar
Probably bad computer, gets hot and shuts down till it cools off.
Old Nov 15, 2013 | 11:45 AM
kampendmk's Avatar
check ground wires
Old Nov 17, 2013 | 05:04 PM
Ill double check the ground wires again and where's the computer? Thanks for all the help guys
Old Nov 18, 2013 | 06:21 AM
maybe a bad module inside he dist. They get hot and the car won't run until it cools back off. I forget the name of the part. short term memory problems. I'll remember the name in about an hour.
Old Nov 18, 2013 | 03:12 PM
It's has coils
Old Dec 12, 2013 | 06:56 PM
It's at it again. It's been acting up real bad now. It'll die and the check engine light won't come on. I hooked it up to my scanner and nuthin... It's doing it like ever 30min of driving
Old Dec 13, 2013 | 09:48 AM
roger blose's Avatar
Sounds like the classic ignition module failure. The module is on the side of the distributor held on with two 7mm bolts. You need a special socket to change this unit out. They fail with age and heat. When they cool off, they work again like a thermal switch. Class action law suit years ago and some folks were killed when these units died while driving I believe.
Old Dec 13, 2013 | 06:49 PM
That's what I was talking about. I had one go bad on a cheby I had years ago. It was inside the dist on that car
Old Dec 15, 2013 | 08:25 AM
Oh dang. But I already changed out the ICM about four months ago. Mine is on the intake manifold. Do you guys know if the have repositioning kits for them?
Old Dec 15, 2013 | 08:26 AM
Mine is on the intake because it has coils
PonyShow
V6
Nov 17, 2017 02:00 PM
ssjbuu
Aug 28, 2015 08:55 AM
pretender
2011 - 2014 GT/CS
Jul 17, 2015 03:29 PM
Rodsmustang
Which is Better
Jul 14, 2015 02:09 PM
