Intake
Old Jan 27, 2013 | 10:17 AM
fiveohrell's Avatar
Intake
Which intake is one of the best?or works the best?
Old Jan 27, 2013 | 01:25 PM
skunk21's Avatar
for what combo . there will be limited improvement but improvement none the less going with an aftermarket intake or gt40 intake with stock heads.
The cobra intake or ford racing cobra intake, exporer gt40, trickflow street, edelbrock rpm/performer, holley systemax, etc are all good intakes and will be even better with good heads and a cam. stay away from box intakes and "R" intakes on a stock or mild combo.
really they all flow pretty good. the chinese ford racing cobra intake ( post '03), explorer gt40 & proffesional products intakes ( due to thier poor casting/flash issues) flow on the lower side.
A real '93 cobra intake and the tubular gt40 are the next step up.
trick flow, holley, edelbrock are all pretty close.
I have GT40 info and flow info in our tech thread.
Old Jan 31, 2013 | 09:23 PM
nicksranger01's Avatar
I've got a trick flow street burner, with a 75mm throttle body and a CAI and it puts some power down compared to the stock crap it had...if your still running a stock TB definitely change that with the intake
Old Feb 9, 2013 | 08:16 PM
Batmobilebrock57's Avatar
Go with trick flow good brand. And if you don't like what you get out of it they will take it back within a certain amount of time. Rpm rate is up to 6500 with the tfs streetburner. You probably can't go wrong with anything skunk21 says either so your best bet is to listen to the wise men of this site
Antigini-GT/CS
Oct 5, 2015 09:43 AM
RoushRS3
Sep 29, 2015 08:03 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
