Idle surge up and down car shuts off
Old Mar 12, 2013 | 03:30 PM
Lethal_pony's Avatar
New build, 92 5.0 bored 30 over forged flat top pistons new e303 cam 24lb injectors calibrated 24lb maf afr 165cc heads crane cam roller rockers. Bbk upper and lower intake. Bbk headers. New plugs wires dist. and coil. Car won't idle, shuts off. Been told that I need a idle air control adjuster. Any similar problems or suggestions??
Old Mar 12, 2013 | 03:42 PM
skunk21's Avatar
has the car been tuned? did you check for any codes ? There can be driveablity issues with a calibrated maf. even though the aftermarket sells a 'scaled' or 'skewed' maf/samle tube to trick the ecm when using a different size injector sometimes there can be driveability issues, etc. where as when a proper tune is done you get an ecm recalibration, done. End of guess work. I'm not going to say for sure this is the problem but lots of times the calibration is a problem. check for codes.
Old Mar 12, 2013 | 04:26 PM
I'm gonna check right now. Thanks
Old Mar 12, 2013 | 10:06 PM
hi5.0's Avatar
IAC adjuster? You mean the metal plate with 2 adjustment screws? Hasn't worked for me yet. FWIW, sometimes those aftermarket MAF meters are sensitive to placement ("clocking") and intake airflow turbulence from RAI vs. CAI. May as well double check TPS setting too. Good luck.
Old Mar 14, 2013 | 04:27 PM
skunk21's Avatar
The idle air plate for the most part is a bandaid, but it does work and I have one my car. I had surging idle issues after my mods. Now before the arguments start I always advocate finding the problem and fixing it. I did the code test, base idle reset, TPS check, vacuum test, clocked the maf, etc, etc. It helped but never totally fixed the issue and I never could hunt it down. I gave in and got the plate and it fixed the problem, never had and idle problem since.. go figure .
Since we haven got a responce back yet. I will still say trouble shoot 1st. check for codes, do a base idle reset, etc. the problem may be rectified sometimes though you have to restort to other methods.
Old Mar 15, 2013 | 11:14 AM
Ok so car is fixed after a iac adjuster plate and a new tps. Car still ran rough after all that so we unhooked the bbk maf and the car would start up and run fine. Just had check engine light on, of course. Ran a little lean so we switched the maf back to the factory one and the car is doing fine now. Don't know y my 24lb injectors won't run with the bbk 24lb calibrated maf, but it doesn't.
Old Mar 15, 2013 | 11:29 AM
skunk21's Avatar
Bad maf or bad calibration. read post #2.
Diode Dynamics
Jun 12, 2018 03:26 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
Kestral
Jul 29, 2015 10:26 AM
Rodsmustang
Which is Better
Jul 14, 2015 02:09 PM
