Idle problem
Old Mar 24, 2012 | 03:42 PM
darkhorse93's Avatar
Idle problem
I have a 93 gt and after the car gets warmed up it starts to idle alot higher than normal. I don't know where to start on the problem. Thanks
Old Mar 24, 2012 | 06:05 PM
onebadvert's Avatar
I would set the idle the proper way as described in your haynes or Chilton.then check and or clean maf tps and Iac.then also check for vacuum leaks including ;lines,intake, injector o rings etc etc.
Old Mar 24, 2012 | 06:33 PM
I can't mess with my idle to much, it's supercharged. Vacuum lines look good no leaks
Old Mar 24, 2012 | 06:51 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Define "high"?
Old Mar 24, 2012 | 07:43 PM
I usually idle around .6-.8 and now it is 1.3 or a little more
Old Mar 24, 2012 | 09:38 PM
skunk21's Avatar
Clean the iac. The iac can be an issue for our cars, carbon gets in them and causes problems. also run a KOEO test for codes, these cars can have codes W/O showing a check engine light. You still running EGR?
Old Mar 25, 2012 | 01:49 PM
So I cleaned up the iac real good just waiting it to dry and then I'll fire her up
Old Mar 25, 2012 | 07:44 PM
I ran the car and it still was ideling high. So I ended up adjusting the idel screw
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
Airborne42
Sep 24, 2015 11:01 AM
