Idle problem
I would set the idle the proper way as described in your haynes or Chilton.then check and or clean maf tps and Iac.then also check for vacuum leaks including ;lines,intake, injector o rings etc etc.
Clean the iac. The iac can be an issue for our cars, carbon gets in them and causes problems. also run a KOEO test for codes, these cars can have codes W/O showing a check engine light. You still running EGR?
Rando
Aug 25, 2021 11:12 AM
