help me no start
Old Dec 16, 2010 | 08:33 PM
wanajmpstang's Avatar
Angry help me no start
I have an 89 mustang gt that caught on fire!!!
put in a used harness from another 89 gt but from a stick this one is an auto.
turn key on all lights and everything work.
but..... no fuel pump kicking in, starter doesnt engage, and no spark
need any and all suggestions
Old Dec 17, 2010 | 09:04 AM
lxlaw's Avatar
Sounds like you are not getting a signal from your ignition.
Old Dec 17, 2010 | 02:16 PM
x21's Avatar
x21
If you don't already have this link- its quite helpful in breaking down your wiring- http://www.veryuseful.com/mustang/tech/engine/#Diagrams . Where exactly did that fire originate? headlight/foglamp switch or ignition or somewhere else?
Old Dec 17, 2010 | 02:26 PM
lxlaw's Avatar
Well the only thing that makes me tell you this is the starter has nothing to do with the computer system. But the positive signal to the computer has the same reference. No fuel pump and ignition tells me your not getting a 12 volt signal.
Old Dec 17, 2010 | 03:24 PM
afr347strokerman's Avatar
I had a similar problem...got a new harness. The wires are very sensative when you start playing with them-just takes one to ground out or come loose
Old Dec 18, 2010 | 07:37 AM
help
So you think its the ignition switch then?
I have had people tell me that it could have to do with the fact that this car is an auto and the harness came out of a stick. could that be it?
I can tell you that if I jump the selonoid I can get the car to turn over, but still no spark.
Old Dec 18, 2010 | 07:39 AM
help
so what can i do ?
anyone live in wisconsin that wants to figure this out!!!!!
Old Dec 18, 2010 | 07:46 AM
lxlaw's Avatar
Originally Posted by wanajmpstang
so what can i do ?
You need to get a circuit tester and check your ignition voltage source. You are not getting a 12 volt signal to your computer and solenoid. You are not getting signal from your switch. It may be as simple as a fuse or a cut wire, it could be the switch if it shorted out in the fire. Just do some testing. If I was near ya u would do it for ya.
Old Dec 18, 2010 | 08:32 AM
so the swiych will turn the accesoiries on like blower etc. I do have another colum and switch out of donor car. have to try that
as far as voltage to computer etc please dont tell me that wouldnt have anything to do with somesort of neutral saftey switch.Where r u from?
Old Dec 18, 2010 | 09:04 AM
lxlaw's Avatar
Well if you have power inside then the switch is working. So you eliminate that. It sounds like there may be a plug not plugged in. Check all the connections by the brake booster. Follow the wire that activates the starter solenoid and make sure it is plugged in. Make sure that plug is not damaged. I am in Texas, you can call me if you need. 361-726-2969
Old Dec 18, 2010 | 09:07 AM
OK BUT WILL THAT ALSO STOP THE FUEL PUMP AS WELL? REMEMBER I DONT HAVE ANY POWER TO THE PUMP
Old Dec 18, 2010 | 11:05 AM
lxlaw's Avatar
The fuel pump us controlled by the computer. It sends a signal to the relay.
Old Dec 18, 2010 | 04:16 PM
lxlaw's Avatar
There is a key ignition switch where the key goes, then there is an ignition switch under the dash that sends power to the car. They are known for going out, in fact they were recalled on the late 80 models. Just use a test light with the key on and see where it goes. I will see if i can find my wiring diagrams to give you some direction.
Old Dec 18, 2010 | 05:46 PM
that would be awsome
Old Dec 20, 2010 | 08:42 PM
is the wire harness different from an auto to a stick shift
Old Dec 21, 2010 | 04:02 AM
lxlaw's Avatar
Not really, there is a different pig tail at the tranny. Do you have a standard? Is it out of an auto? It may be the neutral safety switch, but that shouldn't keep it from priming the fuel pump.
Old Dec 21, 2010 | 04:47 AM
That was my first thought was the netural saftey switch wire.... but
Old Dec 21, 2010 | 05:11 AM
car is an auto harness is out of stick, will it matter
Old Dec 21, 2010 | 09:13 PM
lxlaw's Avatar
well if you had an engine fire, you should have been able to save the harness for the tranny and just snap it in place. The same main harness, it is just the part of the harness that plugs in down near the transmission. You should have been able to plug yours right into the harness.
Old Dec 23, 2010 | 06:39 PM
GOT GOOD NEWS GOT IT TO TURN OVER SPARK AND IF I RUN A JUMPER WIRE TO THE FUEL PUP IT RUNS NOW I AM MAKING SOME PROGRESS, HAD TO WIRE THE NEUTRAL SAFTEY SWITCH IN ORDER TO GET IT TO START
09-gt/cs
Oct 15, 2015 10:03 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
GLOCKer
Sep 28, 2015 05:20 PM
