heads
Old Apr 12, 2013 | 06:33 PM
notchos 90's Avatar
heads
I have a upper and lower intake from a explorer it came with the car (not installed) the previous owner said he put in a e303 cam roller rovkers and did a little porting on the stock heads also has a 410 with a 3000 stall and shift kit its a aod, my? Are 1 are the heads on the explorer the same as on the foxbody cobras and would it be worth me installing the explorer heads with the u/l intake as far as better performance. I'm on a buget and can't do aluminum heads.
Thanks.
Old Apr 12, 2013 | 07:21 PM
91notchback's Avatar
The heads are the sweet spot of the swap. The valve size alone is worth it. Not sure of the porting/polishing on the stock heads. I had my gt40s rebuilt, 5 angle valve job, ported, polished, and gasket matched. And my intake ported, polished, and gasket matched. Not a bank breaker!
Old Apr 13, 2013 | 07:32 PM
notchos 90's Avatar
What would be a good $$$ for the heads? thanks 91notchback.
Old Apr 13, 2013 | 07:56 PM
MustangFrontier's Avatar
Explorers cam with GT40 and later GT40p heads. The valves in the p are different and they have revised spark plug angles. The 93-95 cobras had GT40 heads that gave higher compression then the explorer ones. You can mill the explorers for the same result.
Old Apr 13, 2013 | 07:58 PM
Also have the valve springs been changed on the set you are looking at? I wouldnt pay over $300 for a excellent condition set unless they have been worked.
Old Apr 14, 2013 | 01:49 PM
notchos 90's Avatar
This guy on Craigslist is selling me a 98 Explorer 5.0 with the gt40p heads for $600 complete running motor.is this a good price? since I have the upper and lower intake already but he won't part out the motor.
Old Apr 14, 2013 | 02:06 PM
I would just try to find a set of P heads on eBay if you're motor is good. The cams in those are garbage, and the springs would need to be changed in the heads anyway. Not a bad price on the motor, but there are better ways. Once again, I do understand how budgets go.
Old Apr 14, 2013 | 02:26 PM
AlsCobra's Avatar
A Man Just Needs Some....
$600 is not far from the price of a good set of heads. Save your money and go for the good stuff. Patience will pay out in the long run. Otherwise you'll never be satisfied with those $600 cast heads. I went with the Windsor Jr's on mine and should have saved a little while longer and just got the trick flows.
Old Apr 14, 2013 | 03:07 PM
+1 I just looked on eBay, and the prices on P heads are outrageous now!!
Old Apr 14, 2013 | 08:02 PM
notchos 90's Avatar
There's a set if gt40 p on eBay for $500o.b.o +shipping and if you have a performance cam its more $$$.
Old Apr 14, 2013 | 08:41 PM
Because they'll have to upgrade springs. Your e303 will need them. Are they rebuilt?
Old Apr 14, 2013 | 09:11 PM
notchos 90's Avatar
Yes they are rebuilt.
Old Apr 14, 2013 | 09:22 PM
If he wants to know if aftermarket cam, that means they are stock an weak springs. Here is a good deal on aluminum heads;
http://www.speedwaymotors.com/Flo-Te...ads,46332.html
There was a magazine write up somewhere whew they made good power! I almost went with them till I found my gt40s. Still kinda think about it, but I have WAY too much in my heads now!
Old Apr 14, 2013 | 09:40 PM
onebadvert's Avatar
I agree. From the research I have done on the fko teks, they are pretty decent heads. They wont compete with afr or trickflow. But they are a step up from the gt40s and you will also get the advantages of aluminum heads. Like better cooling properties, lighter weight, and less harmonics. For the price I dont think they can be beat.
Old Apr 14, 2013 | 09:45 PM
I'm sure you know what I've ran my gt40s through...lol! I pick them up next week. I've heard mixed things about what they'll do. Opinions?
Old Apr 14, 2013 | 09:49 PM
onebadvert's Avatar
Yours have been worked so they will probably be pretty darn good. Your car will prolly feel like a while new animal im sure.
Old Apr 14, 2013 | 09:57 PM
My wife tripped when I put my LTs and x pipe on, took her around the block 1 time, brought her back in the garage, and started tearing her down...lol! She was wore out bad!!!
Old Apr 14, 2013 | 10:14 PM
My wife said I should clear up: the motor in the car was wore out.... Not my wife!LMFAO...)
Old Apr 14, 2013 | 11:09 PM
notchos 90's Avatar
Thanks I'm going to look into those aluminum heads they are not that $$$.
Old Apr 16, 2013 | 02:14 PM
dcpirani's Avatar
I think those are the heads MM&FF used on the 85 Capri 4 barrells of fun. they did not dyno the car, just track tested it.
