Header Size
Old Jun 30, 2004 | 09:38 PM
88blueGT's Avatar
Heres my problem... I just recently ordered MAC Long Tube headers. They are 1 5/8 pri and a 2 1/2 collector. They will be put on my 302. The problem is I just recently decided that in a couple months I want to get a new engine. Its a DSSRACING 347 Pro Bullet Long Block pushing 490-510hp. Will these headers be OK with this set up or should I invest in larger tubes and collector size. And just to let you know I rather stay with a smaller size if they are going to pull more torque. Thank you in advance for all the help.
Old Jul 3, 2004 | 09:30 AM
bob's Avatar
bob
probably want to go bigger on header size, 1-3/4 LT's work pretty good on most medium displacement small blocks in your HP range. 1-3/4 LTs, 28 or so inches long (if your keeping it along a 6500 peak power range) with 3 inch collectors. Pretty standard stuff. As for the rest of the exhaust I would reccomend a good x-pipe and some bullet mufflers.
Carb'd or injected?
Old Jul 11, 2004 | 09:57 PM
88blueGT's Avatar
The car is fuel injected, Im now still not sure what header size I want because Im kind of undecided on what engine i am getting. I was looking at the 347 but I dont think that it is streetable for me to drive. I just dont think that I can afford it so now I im looking at the 306 which is putting out 390-410 depending on the cam that I use.
Old Jul 12, 2004 | 04:49 PM
bob's Avatar
bob
a 347 can very streetable, as long as the pistons can properly support the oil ring (r/s ratio is of little concern here, pontiac's 455 has a worse r/s ratio than a 347)
You can go with an 1-3/4, will still work pretty well (1-3/4 x 30). or a 1-5/8, but the smaller headers actually require longer primary tubes with the same basic rev range.
I dunno if this will help, but
http://www.airflowresearch.com/
hit the dyno tab tests and compare engines to yours, however it looks like an 1-5/8 LT would support 400 hp nicely
Old Jul 17, 2004 | 11:29 PM
88blueGT's Avatar
looking at the website I think that Im going to go with the 1 3/4 because I plan on doing major work and going by the numbers shown on that website It looks like I might need them. But I have one problem, do you think that I can put the 1 3/4's on my 302 before I get my new engine without any problems?
Old Jul 18, 2004 | 11:02 AM
bob's Avatar
bob
As long as it uses a standard Ford exhaust bolt pattern, NP. However the 1-3/4 primary dia is a bit big so exhaust flow will slow down. I'd just wait for the new engine to come along
Old Mar 11, 2005 | 10:05 PM
88blueGT's Avatar
Thanks alot for all the help. I eneded up getting the MAC Longtube 1 5/8; 2 1/2 col. ceramic coated headers with the 2 1/2 MAC Pro Chamber H Pipe (off road- no cats).
Old Mar 18, 2005 | 09:01 PM
Fordracing200's Avatar
wow, whos checkbook do you have acess to? I thought you were selling it? So you are gonna keep the stang and put a new motor in it?
Old Mar 19, 2005 | 11:30 PM
88blueGT's Avatar
I go to school and work 3 jobs. Its my own checkbook.... unfortunatly.
Old Mar 21, 2005 | 01:59 PM
oic, i was JW, since you were gonna sell it. Too bad you dont have acess to Michael Jackson's checkbook, where hes going hes not gonna need it
Evolution Performance
Northeast
Aug 5, 2016 12:46 PM
FromZto5
Sep 30, 2015 05:28 AM
Feffman
Sep 28, 2015 06:46 PM
Feffman
Southeast
Sep 24, 2015 05:06 AM
Kestral
Sep 2, 2015 06:52 PM
