Hatch not latching...
Old Apr 2, 2007 | 01:28 PM
Desi's Avatar
Ok, got the 82, she's in great shape but the rear hatch wont latch, the mechanism seems to work fine, but I dont know if the striker bin has dropped, the latch has been bumped up, or a combination of the two... any advice on how to correct the issue & if the pin can be moved at all?
Old Apr 2, 2007 | 01:43 PM
Puter's Avatar
Any HELP section at any auto parts store has the plastic bushing that is probably broken and gone. Look at your striker and see if there is only skinny metal. It should have a bushing. Look at the picture in the below URL and see if yours is gone.
http://images.latemodelrestoration.com/LRS-40442A.jpg
You could also buy the whole setup. See the below URL.
http://www.latemodelrestoration.com/...0%201&comp=LRS
If you are really cheap, you could run some electrical tape or such around the post several times unless it latches. I think this work is along the same lines of putting a piece of cardboard over a floorpan hole.
Old Apr 2, 2007 | 01:48 PM
Desi's Avatar
Ok, thanks, I'll check when I get home..I BELIEVE it is just the metal post, but that sleve ya say would keep it from lathin eh? This is the reason I got into the hobby & love this forum.
Old Apr 2, 2007 | 02:28 PM
Valentino's Avatar
That striker bolt Ralph linked to is the same part I bought (but for a '90) and it fixed the god awful hatch rattle I had. I also had to adjust the striker a little bit to make it latch perfect which requires either a T45 or T55 Torx bit I believe, which you can get at the parts store.
Old Apr 2, 2007 | 04:43 PM
Puter's Avatar
Yep.
LMRS also has a whole "hatch repair kit" that contains that whole striker assemble, a new seal, and 2 new shocks. When adjusting - like Angelo mentions - there are also two rubber bumpers at the corners of the hatch. Replace/adjust those if needed.
Thanks, Angelo.
Old Apr 2, 2007 | 05:07 PM
Valentino's Avatar
oh yeah I forgot about those rubber bumpers, I replaced those too and it helped a lot with the hatch adjustment
Old Apr 2, 2007 | 05:34 PM
jacostang's Avatar
This is just a strange thing to have this post pop up, my hatch stiker just gave up the ghost over the weekend and the show. Need one!!!
Old Apr 2, 2007 | 06:52 PM
Desi's Avatar
Heh, this kids, is why ya shouldn't post from work..
Spelling errors aside, yeah I need that kit, mainly for the sleeve/shocks, the seal all seems good still, but parts-is-parts like the old comercial goes...also looking over it again, I need the sleves for the doors, as well
Old Apr 2, 2007 | 10:32 PM
kevinspann's Avatar
Post
all seems dood still
lol
Anyway the door striker bushing can be found at the parts store too, they come in a pack of four, two short ones, and two longer ones, the longer ones is what you will need. It should be the same size TORX bit as the hatch, which i believe a T-50
Old Apr 4, 2007 | 08:17 PM
tn89lx5.0's Avatar
My hatch wouldnt latch unless I slammed it. It had black tape around the striker bolt when I bought it and it did rattle some. I bought the bolt with the bushing for less than 40 bucks and it solved my problem. Its and expensive little piece but its worth it to secure your car and stop that noise! Its a place to start....
Old Apr 4, 2007 | 09:51 PM
Desi's Avatar
Well, this is my latch, after lookin at it more closely, the piece on the left can be manually moved with ease, there is no tesion on it, unless I push it by hand to the "close" position, then it locks..
Old Apr 5, 2007 | 07:12 AM
Puter's Avatar
It is working as it should.
Old Apr 5, 2007 | 08:00 AM
svopaul's Avatar
Service Manager
$40?!?....those things only cost around $15!!
Old Apr 5, 2007 | 01:58 PM
Desi's Avatar
hmm, any thoughts as to what else it could be? Body/seals seem to good to be frame damage ( a friend o mine suggested, but havent gotten into a shop yet...doesnt seem likely to me).soo, recomendations?
Old Apr 5, 2007 | 02:44 PM
Puter's Avatar
The striker did not help?
Old Apr 5, 2007 | 03:24 PM
svopaul's Avatar
Service Manager
That is normal...and not your problem. Your problem is the striker that is mounted to the rear body panel.
Old Apr 5, 2007 | 04:10 PM
Desi's Avatar
ok, so it can be moved then? looking at the replacemts I thought it was just a bolt, basically. looks like I am gonna have to yank off all the plastic crap/panels, thanks for the info =)
Old Apr 5, 2007 | 05:11 PM
svopaul's Avatar
Service Manager
Yes, the bolt is adjustable...the missing plastic bushing is what is causing it not to latch.
Old Apr 5, 2007 | 06:05 PM
Puter's Avatar
Originally Posted by Puter
Yep.
Yes, that sleeve would keep the hatch from latching.
Old Apr 5, 2007 | 06:47 PM
Desi's Avatar
that's just it tho, picked one up (labeit one of the "Help" brands from Advanced Auto) to test it.. no dice...maybe I do need to try & raise it, I thought the striker was just a bolt, didnt realize it was adjustable.
