gt40 heads
Old May 10, 2014 | 03:02 PM
gt50convert's Avatar
gt40 heads
im looking at a set of gt40 heads on fordparts.com from a 1997 mountaineer for 240.18 would they be worth the money.
Old May 10, 2014 | 03:09 PM
AlsCobra's Avatar
A Man Just Needs Some....
Worth the money but not worth buying. If you want a set of good heads, just hold out and buy a good set. The GT40's just won't give you what your looking for. Trick Flow, AFR.
Old May 10, 2014 | 04:50 PM
im building a sleeper im looking for gt40s or gt40p. dont have the money to save up for afr or trickflow. a friend of mine told me about flotek 5.0x heads
Old May 10, 2014 | 07:13 PM
MustangBillJr's Avatar
People constantly give you advice on what to buy and you always choose the cheapest route. If you don't have the money to save for a good set of heads, then you don't have the money to put together the right combination of parts to do a GT40 based build any justice.
Old May 11, 2014 | 12:53 PM
im going gt40 heads shorty headers tfs valve spring upgrade frpp hardened pushrods frpp lifters. i want to know if a tfs stage 1 will work with factory length pushrods and factory rockers
Old May 11, 2014 | 01:03 PM
AlsCobra's Avatar
Honestly anything less than a set of gt40x heads is a waste. The trick flow stage 1 cam will work with stock length pushrods but honestly you're pissing in the wind. I went with Victor jr heads with tf 1 cam and it sounded fantastic but the car was still weak. Get on eBay and Craigslist and find a good used set of heads.
Old May 11, 2014 | 01:47 PM
i can get gt40 heads locally for ridiculously cheap. i am also going to run tfs valve spring upgrade with the tfs stg1 can i keep my factory rockers
Old May 11, 2014 | 03:11 PM
ALMOST STOCK's Avatar
Might be something that you might want to look into.
http://www.fiveohinfo.com/performance/gt40-gt40p.html
Old May 11, 2014 | 08:43 PM
You go and ask these very same question on the Corral and get the same answer of AFR's or Trick Flow 170's and you ignore the suggestions again..... lol. Why waste everyone's time with your posts? If your pinching pennies to build your car I don't put much hope in this "sleeper" status you hope to achieve.
Old May 13, 2014 | 12:11 AM
bob's Avatar
bob
Agreed, nice heads and if I were looking to do a simple rebuild I'd go for a set but anything more than that and I'd spend the money on a good set of heads.
NC14GT
Sep 10, 2017 04:47 PM
Sep 30, 2015 07:02 PM
earl610
Sep 7, 2015 11:57 AM
