Gas gauge problems
Old Dec 17, 2015 | 05:34 PM
Mustang89LX's Avatar
Gas gauge problems
I am having some issues with the fuel gauge on my 1989 Mustang Lx 5.0 automatic. Here is my problem if the fuel gauge is below the full markand I shut the car off the fuel gauge will drop and not return to the last spot that it was when i shut the car off. The gauge is sometimes as much as an 1/8 of a tank off sometimes it will go back up to were it was and someimes it wont. Any help would be awesome. Thanks
Old Dec 17, 2015 | 11:38 PM
houtex's Avatar
1 - Bad Sender.
2 - Bad gauge
Not a real good way to figure either out except to swap 'em. I'd do the sender, as an '89 is probably 'due', if you will, to have that go out. The gauge is unlikely to be the problem, but there are occasions... probability is the sender.
Means yer droppin' the tank, so run it outta gas, then unstrap it and swap it out.
http://www.cjponyparts.com/fuel-tank...FNSxoCYmfw_wcB
That's an example of the part, and has a lil' video by Bill and the guys, and also installation under that so you can have a look see to see if you wanna do it yourself.
Good luck!
Oh, and welcome to the forums!
Old Mar 2, 2016 | 12:46 PM
subsonic99's Avatar
Try replacing the anti-slosh module on the back of your gauge cluster. That is similar to what mine was doing and it was the last thing I replaced. You can get them on eBay from $25-45 dollars used.
JustDensyl
Nov 24, 2015 07:30 PM
outlaw_50
Oct 27, 2015 09:37 PM
dohc97
Oct 22, 2015 08:15 AM
Fedupdave42169
Oct 20, 2015 10:29 PM
