Fuel injection to carb!
So I'm going to do a carb'd 351 set up in my 93 notch, it currently has a 2.3L 4 banger, iwas wondering if anybody has done this before and need some ideas on how to set up the fuel system, or if anybody has a link regarding this can you please send it to me, thanks in advance.
Excepting the fuel system, and computers, there's not gonna be much difference than just swapping for a 5.4, or a 5.0 for that matter. Still have to do suspension upgrades, probably the rear axle swap, and driveshaft.
And... it won't pass emissions, so if you're in that sort place, there's that.
The fuel system.. you'll have to replace the in-tank fuel pump with a low pressure one, and cap off the returns as needed, or otherwise modify, because the carb can't handle the high pressure flow of the injector setup for fuel. Perhaps a pressure regulator...
But it's still a huge swap, even if you were goin' EFI. Have fun with it.
Most of the general concepts can be googled. As far as why anyone would do this... well... I'm sure you have your reasons.
9/16/15 06:44 PM
