Fox Tech: Quick links & Articles.
Old Feb 12, 2013 | 01:47 PM
skunk21's Avatar
ENGINE
NO START
G.T. 40 Heads & Intake info
351 Swap
4cyl to V8 conversion
5.0. Belt Routing
Converting explorer TB
Mass air meter interchange
Block strength/broken block info
Adjusting rocker arms
Mass air/speed density explained
Mass air conversion
Normal oil pressure & stock fuel pressure ( EFI )
Camshaft lift and Duration theory
Understang cam specs
Choosing a cam
Checking piston to valve clearance how to
Setting pushrod length
Testing fuel sending unit/fuel gauge
O2 sensor code troubleshooting
Base idle reset
DRIVELINE
Clutch Adjustment
Clutch quad info
Clutch cable install how to
T5 Conversion
T5 I.D guide
T5 service manual
Gears & speedo correction
Rearend info
rearend dimensions
Rear gear install how to
HEATING/COOLING
svopaul's heater core
Heater core how to
SUSPENSION/STEERING
Steering rack limiter how to
Watchdevil's Tilt wheel conversion info
BRAKES/5-LUG CONVERSION
Brake upgrade/5-lug conversion
SleepingStang 5 lug conversion
Bleeding brakes how to
Irs swap into a fox how to
EXHAUST
Exhaust info
TECH
EEC-IV codes 86-93
Air bag tech
Starter wiring diagrams/ mini starter how to
Compression test/Cylinder leakdown test
Testing Battery/Starter & Charging system
Wiring harness differences
Autotooner
Nov 24, 2017 12:42 PM
Sep 30, 2015 07:02 PM
