Emergency brake cables
Old May 13, 2008 | 09:35 AM
WaltM's Avatar
All,
Has anyone replaced theses? Mine is really stretched out and needs to be replaced, but I don't know what to order. Anyone have a parts list?
Walt
Old May 13, 2008 | 03:57 PM
Valentino's Avatar
For your SVO, right? Heres the cable, http://www.latemodelrestoration.com/...0%201&comp=LRS
Not sure if theres anything else required, LRS also sells the guides but thats about it for your model.
Old May 13, 2008 | 04:25 PM
WaltM's Avatar
Thanks. I didn't know if there was a third cable that the two sides tie into. Any idea ?
Old May 19, 2008 | 03:46 PM
svopaul's Avatar
Service Manager
There was a guy on the SVO Club board who bought those from them and they were not correct, you would have to fabricate your own pins to secure them as the bracket is too wide for the factory one and they do not supply you with a new one. They said they would take them back but when he asked if they would continue selling them knowing they were not correct they indicated they would....so beware of those.
Old May 19, 2008 | 03:50 PM
WaltM's Avatar
Paul;
What about the stuff at Pep Boys etc. I don't mind paying extra for the right part, and these sorts of places seem to have them.
Btw, do you have a source?
Old May 19, 2008 | 04:02 PM
svopaul's Avatar
Service Manager
I'm not sure about the Pep boys ones....I've used replacements from NAPA before and they've worked fine but I don't often need SVO ones as I have a stash of used ones. I can probably help you there if you want to go that route. If you go with new just make sure that everything looks the same but the primary problem is the thickness of the bracket at the caliper. At least with Pep boys or other part you can compare before you buy and avoid the shipping hassle.
Old May 19, 2008 | 04:13 PM
WaltM's Avatar
Napa eh? They're all over the place around here. I'll check them first.
boz
Oct 1, 2015 04:47 PM
Rando
Sep 30, 2015 12:28 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
