EGR question
EGR question
I have a 90 gt conv. And it is throwing a egr valve position sensor code. The pic i have attached is of the egr valve. It is the small lighter color between the two other valves. The eleftrical adaptor for the valve is directly to the left of it. Is this a egr delete?? I bought a new sensor and cant fidn where to install it because this valve has a small line connected to it. Im not sure wuat is going on with my situation. Can someone help me?
That is not a pic of the egr valve. That's a pic of 5.0l with a missing egr valve. The egr valve goes on the egr spacer between the throttle body and the upper intake plenum. Also what's that connector with nothing plugged into it? Buy yourself a service manual man. Good luck!
I have A manual but it doesnt have a pic in it. That adaptor is for thebegr valve. I though the middle valve was a bypass valve or something. Can u post a pic of what the egr should look like. A pic in a motor. Thanks for ur help.
It actually threw code 31, 41, 91. Which is the egr valve position sensor. But my car doesnt have an egr valve, i guess. I am trying to figure out where it would go and i cant see even where the delete is. But the car runs fine. It usually wont stay cranked when i first start it cold for like a minute and then it runs fije. But i want to getbthe check engije light taken care. It also shows o2 code. I need change those. Any idea on the egr valve?
Looks like the connector with nothing plugged into it is the one for the EGR valve position sensor. The EGR delete should be a plate bolted near the throttle body on the spacer toward the firewall side that covers the hole. Possibly the one with the threads sticking out (should be 2 bolts) in the foreground of the picture. Unless your car also does not have a throttle body/EGR spacer. You're also going to need to find out if the vacuum line leading to the EGR valve was plugged or removed.
My car currently does not have the EGR valve hooked up (no EGR/throttle body spacer and won't clear even with a cowl hood) although it still has the electrical connection for the valve position sensor hooked up and kept in the 'neutral position' through the ingenious use of velcro.
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
