driveshaft rubbing the firewall after a drop with springs
Old Nov 4, 2009 | 02:52 PM
touring's Avatar
i guess the 4 cyl. mustang have a balancing ring on the driveshaft and the after i dropped it about a inch and a half its rubbing with there's a heavy load in the car. the mech. sdaid i have 3 options hit the firewall so i can make it wider and not rub,get stock springs again or get a new drive shaft. i dont want to bang the car up,so that leaves me with 2 options. where can i get a drive shaft that will fit without that balancing ring? i really dont want to get stock springs again . it only rubs on a really heavy load. thank guys
Old Nov 4, 2009 | 09:21 PM
DynamicmustangGT's Avatar
you could have someone cut the opening out and weld a new piece of metal with a wider opening
Old Nov 5, 2009 | 03:43 PM
touring's Avatar
man, didnt want to put more money in it.
Old Nov 5, 2009 | 05:21 PM
You can try searching but mustangs unlimited and other factory sized parts dealers don't have many 2.3l parts in stock and not many people even make aftermarket parts for them. I don't believe the 5.0 driveshaft will mount up right.
Old Dec 1, 2009 | 07:29 PM
sgt d's Avatar
not sure if you already addressed this but like stated above there are not a ton of options for you. the least pita would be to split the difference and take it back up a bit. or just finally do the full conversion and make that coupe scream! btw how are things going?
Old Dec 1, 2009 | 07:37 PM
rbinck's Avatar
Seems like the ring is part of the transmission slip yoke and you could get a new yoke without the ring. Try dennys driveshaft. Ford Slip Yokes
Or take your yoke down to a machine shop and have them shave the ring down a bit.
Old Dec 3, 2009 | 10:30 AM
touring's Avatar
it was a blown transmition mount.......... 30$
Old Dec 4, 2009 | 12:40 PM
rbinck's Avatar
Hmmm... I'd be having a talk with the mechanic you spoke of in the OP. Sent you completely in the wrong direction.
Old Dec 4, 2009 | 07:22 PM
hi5.0's Avatar
+1 on a talk with your mechanic if he wasn't the one to look into that after the initial troubleshooting attempt. Perhaps some polyurethane mounts are in order, can be had for less than $30 if you haven't already replaced it.
Old Dec 5, 2009 | 12:39 AM
At least it's nothing outrageous.
Old Dec 10, 2009 | 04:44 PM
touring's Avatar
you see thats the funny thing 2 different mechanics couldnt find out the problem. im just glad i found out what the problem was. i still cant belive they didnt see the problem.
Old Dec 10, 2009 | 05:35 PM
rbinck's Avatar
Not only did they not see the problem, they made up stuff! Expensive stuff.
Old Dec 10, 2009 | 07:18 PM
BoogieNights's Avatar
BoogieNights Studios:
Official Fluffer
Hence why I always do my own mechanic work. I dont trust mechanics nowadays.
Autotooner
Nov 24, 2017 12:42 PM
Fords4Ever
Oct 30, 2015 09:07 PM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
