Notices
Drag Racers
Old 1/19/05, 02:05 PM
  #41
I8URVTEC's Avatar
I saw a couple of notches in MMFF back around October that are kind of what I would like to do with my car. They were both street legal yet they ran in the mid 11's. I have the article at home, wish I could give you a little more info.
Old 1/19/05, 02:08 PM
  #42
Fordracing200's Avatar
I have the article. Did you want to do a 408 stroker with yours or a 302 or a 306?
I would get a 4 inch cowl hood from one of the race only places, so it will have a bubble effect and not look like a rectangle with a ramp in front of it. What is your budget if you were to do this? if you have like 3 grand, you could have a nice 12 second car......
Old 1/19/05, 03:12 PM
  #43
Andy Haynes's Avatar
If you want something still streetable yet you can take to the track and run mid 11's. You need to do a 347 stroker with 150 shot.
Old 1/19/05, 03:23 PM
  #44
Service Manager
svopaul's Avatar
If you have a 347 AND a 150 shot on it and ONLY run 11's you have done something wrong. A properly built naturally aspirated 347 can run in the 11's.
A friend of mine was running 11's with a 170K mile stock hyperuplastic bottom end with AFR heads and Nitrous....
Old 1/19/05, 06:10 PM
  #45
Nitrous is great, but where are you gonna fill the bottle, and you have to fill it alot. There is not many places to fill nitrous in NY.
Old 1/20/05, 08:50 AM
  #46
I8URVTEC's Avatar
Yup that's the article I was talking about. I wish I could do a 408 stroker but I don't know if I could afford it. I may just do what I can with the 302 thats there. I already have the 4" cowl hood, it was on there when I bought the car. My budget is probably a few thousand bucks but definatly spread out over time, maybe a year to two years.
Ideally, I will take that car of the road and get a nice beater to drive during the winters. That engine has 140,000 miles on it so I think it would need a basic overhaul first.
Here is a picture of my car:
Forgot to mention, I would rather run naturally aspired than be on the bottle.
Old 1/20/05, 09:43 AM
  #47
Nathan_H's Avatar
if youve got to rebuild your motor, why not op to have it stroked at the same time. car looks nice, are those white pony wheels i see??
Old 1/20/05, 10:37 AM
  #48
I8URVTEC's Avatar
Yup, those are white pony's.
Old 1/20/05, 01:50 PM
  #49
Welds, 4 cylinder springs, and a air bag in the right rear. Then do you want to run with an auto or Standard. Get a TKO from X2C motorsports if running a standard, but if using an automatic, a C-4 with a Transbrake would be great...IMO
Old 1/20/05, 07:20 PM
  #50
I8URVTEC's Avatar
I thought only automatics could have a transbrake...but I am new to this so probably wrong.
Also, I think I would stick with A/T for the car. I prefer to drive a manual tranny but I have heard that A/T are better for drag racing b/c you can't beat the speed shifts of an auto. That true?
Old 1/21/05, 11:41 AM
  #51
Nope, unless the auto has been built. Get a TKO and speedshift it and you will smoke any stock or near stock automatic tranny. Only a auto can have a Transbrake. WIth a stick, just dump the clutch at the desired rpm. No need for a transbrake.
Old 1/28/05, 04:47 PM
  #52
Nathan_H's Avatar
jsut make sure that your able to put the power to the ground, via drag radials, slicks, etc...
Old 1/28/05, 09:47 PM
  #53
Anymore questions? We would be glad to answer.
Old 1/29/05, 08:33 AM
  #54
conv_stang's Avatar
hey paul, any experience in putting an 03-04 cobra IRS in a notchback?????
Old 1/29/05, 10:47 AM
  #55
IRS comes in 99-04 cobras...IMO Their is some people on the site that have done the swap. Paul will prolly know more than I do on this matter.
Old 1/30/05, 10:19 AM
  #56
conv_stang's Avatar
yeah, but they supposedly used stronger half shafts and 355 gears from the factory
Old 1/31/05, 09:38 AM
  #57
They did use 3:55 gears and used no C clips. Stronger I believe.
Old 1/31/05, 10:08 AM
  #58
Stubborn Bear
TMS Staff
Scothew's Avatar
They did use a hardened 31 spline halfshaft in the 03's. Also another thing is the 03 had slightly stiffer spring rates and the addition of Bilstein struts. Paul has a 03 IRS rear end at his shop that I believe is planned to go into a SVO
Old 1/31/05, 12:13 PM
  #59
that IRS would be great for an SVO which is a cornering Focused car. Any drag car or car with 400hp or so that drags wwould not be so good for it but i would be all for it if i wanted to go cornering. If i had a new SALEEN i would put a IRS in it and go road racing.
Old 1/31/05, 12:59 PM
  #60
88blueGT's Avatar
i def. agree with Andy Haynes but the car still looks good.
Quick Reply: Drag Racers
