Dashlights
Old May 27, 2012 | 12:03 AM
landyachtzrider91's Avatar
Dashlights
My dashlights aren't working in my cluster. Checked the fuse and all are good. So wtf? Is a new cluster I just put in though
Old May 27, 2012 | 12:07 AM
AlsCobra's Avatar
A Man Just Needs Some....
I believe it goes through your headlamp switch. Probably gonna be the culprit.
Old May 27, 2012 | 07:06 AM
skunk21's Avatar
1st check to make sure the dimmer switch isn't off, also the dimmer switch could be faulty ( it plays a role in the back lights). check the bulbs in gauge pod but you can also test the circuits including the headlights like Al stated.
headlight diagram:
Old Jun 1, 2012 | 11:38 PM
hi5.0's Avatar
Dimmer switch is a known problem area on these cars. I've had my instrument cluster go dark too - just "jiggle the switch" by turning it through its full range of adjustment and see if the dash lights up when you activate your headlamp switch. If it works, don't touch the dimmer afterwards! If the switch has to be replaced, be aware it can get pricey for what it is. This is A$$uming the cluster and the light bulbs are known to be in good working order.
Old Jun 2, 2012 | 04:31 PM
88foxy's Avatar
Yup it's pretty common on the foxes for the dimmer switch to go bad. It's a variable resistor type which means its a sliding contact so you can try to remove the switch and clean it with some electrical parts cleaner
Old Jun 8, 2012 | 06:11 AM
Thanks guys I'll give it a shot!
Old Jun 10, 2012 | 10:02 AM
Can't believe it worked but just by jiggling the dimmer switch I got them to work ha thanks chaps
DeeJayTJ
'10-14 Interior and Audio
54
Mar 25, 2015 10:28 AM
92 stanger
Dec 10, 2011 02:21 PM
