wiring problem ?
Old Nov 20, 2011 | 03:30 PM
92 stanger's Avatar
wiring problem ?
I just got a 92 gt, Didn't noticed till it got dark but my dashlights come on with the keyswitch, also my taillights and parking lights come on real dim with key on, But when i turn my headlights on dashlights go out? Also when i turn my lights on the taillights are bright all other lights work,Where should i start looking to fix this ? Headlight switch ?
Old Nov 20, 2011 | 03:36 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Dang... Sucks.. tomorrow ill try and pull some wiring diagrams for you.
Welcome to tms by the way!
Old Nov 23, 2011 | 02:58 PM
x21's Avatar
x21
http://www.veryuseful.com/mustang/tech/engine/ May be a good starting point, but a *guess* is maybe at some point the headlight switch was removed and prior to it being replaced, some of the 6 individual terminals came out of the plug and probably got reinserted incorrectly. I had this happen with the other plug for the hazard lights. You can check this by pulling that headlight switch and see if the order of the wiring match up to a known 'good' set up. (an example I found was at http://www.am-autoparts.com/Ford/Mus...34/374686.html ). Good luck!
Edit: did a little more reseach and came upon this- http://imageshack.us/photo/my-images...ghtswitch.jpg/ (credit: http://forums.corral.net/forums/gene...ss-switch.html)
Last edited by x21; Nov 23, 2011 at 03:53 PM. Reason: harnessed the power of Google
Old Nov 23, 2011 | 06:50 PM
92 stanger's Avatar
Thanks guys good info, i haven''t had a chance to look at it yet.I''ll let you know if i find out what it is
Old Nov 29, 2011 | 06:05 PM
92 stanger's Avatar
This mustang has some serious wiring problems, I have checked all the grounds that i have located fuses + fusebox, Besides the lights the starter stays engaged for like a couple seconds everystart i put a new starter and solinoid in today, Still dose it no change. Found out yesterday when it rained that with the ingtion off wiperswitch on the wipers still go but very slow ? Never seen nothing like this how can i check the switch ? I''m gonna check the wire going to solonoid tomorrow to see if it''s staying hot after releasing the key, This car was converted from a auto to a manual wonder if thats got something to do with it ?
Old Dec 1, 2011 | 01:21 PM
92 stanger's Avatar
Got the starter fixed, the relay on the fenderwell was wired wrong. Now if i could figure these lights out, the parking lights will brighten and dim, with dashlight dimmer switch ? Read another post where someone had the same problem in 08 but never posted with the fix
Old Dec 1, 2011 | 04:32 PM
HOSS429's Avatar
legacy Tms Member
almost has to be a ground problem .. the lights are feeding back to ground themselves ..i hate electrical stuff
Old Dec 1, 2011 | 07:22 PM
92 stanger's Avatar
I''ve checked the outside grounds, i'll see if i can find the ones under the dash, I played with the dashlight dimmer switch earler and theres a certain spot, where the parking lights will go out. But the dashlites still come on with the key, Could a bad dimmer switch do this ?
Old Dec 10, 2011 | 02:21 PM
x21's Avatar
x21
Any luck so far? I found this as well: http://www.thatmetalbox.com/automoti...t-Cluster.html I noticed it was a diagram that wasn't included on the first site I suggested.
By the way, my dash dimmer dial has been kind of twitchy itself, but the only thing that happens is the dash lights may go out only if I mess with it. I never noticed anything going on with the parking lights. Hopefully this new diagram may help out some.
May 3, 2026 05:42 AM
Rando
Aug 25, 2021 11:12 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
mx5jhb
Sep 30, 2015 04:44 PM
