Clutch chatter? Is this possible?
Old May 20, 2006 | 04:44 PM
SVT2209's Avatar
I started my 93 stang this morning. It was quit outside and I heard it every once in a while, while I had my hand on the stick some "chatter" or "ratteling". It did not last but more than 1-2 seconds every once in a while but I heard it. I crawled under the car like maybe the exhaust was vibrating against the underbody. But I figured out when I step on the clutch it does not happen. I just purchased the car and I know the previous person changed the clutch because it is extremely hard to step on. I get leg cramps. Nothing compared to my stock 93 Cobra, she's like butter. Is it possible to have some clutch chatter?
Old May 22, 2006 | 07:33 AM
svopaul's Avatar
Service Manager
Not while idling but what you could be hearing might be a throwout bearing. What kind of clutch did the prior owner install?
Old May 22, 2006 | 07:13 PM
SVT2209's Avatar
It is while idling and I do not have any idea what clutch or how old it is. Should I just change it?
Old May 23, 2006 | 07:31 AM
svopaul's Avatar
Service Manager
If you push in the clutch pedal, does the noise change or go away?
I doubt it is the clutch istelf if the noise is at idle...I am thinking throwout bearing.
Old May 24, 2006 | 09:53 PM
GT-Jim's Avatar
did u check to see if its one of the exhaust heatshields under the car? we get alot of rattling and chatter on and off from heatshields on many cars during the day at work... Just a suggestion
Old May 25, 2006 | 06:48 PM
PadreEgan's Avatar
sounds like a throwout bearing
Old May 25, 2006 | 11:03 PM
Stix66's Avatar
^^ This can be a possibility... especially look at the catalytic converter heat sheilds. They fall off or get really loose in the spot welds and rattle here and there, even at idle. Look under the car at those, and if it is not them then I would say it is the throwout bearing.
Gill5oh
Oct 6, 2017 10:50 PM
Sep 23, 2015 03:21 PM
samjluck
Sep 17, 2015 10:24 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
