carb tuning
Old May 13, 2013 | 06:43 PM
onebadvert's Avatar
88 gt
Tfs tw 170 heads
Fti custom cam
.614 int lift
.607 exh lift
1.72 rr
Tfs double springs
Wieand stealth intake
Im running a 670 street avenger carb. I have a wideband af gauge. I just recently upgraded to the fti cam. Before that I was running a b303. With the b303 I was working on getting my af tamed then the lifters went out. So I never really had it better than a 15:1 af ratio.
This 15:1 with the b303 was already increasing the carb jets 4 sizes. Now with the new cam I cant even run it yet. I had it running for a couple minutes and its so lean my headers started turning red quickly. Right now my af is around 18:1.
My question is am I gonna need more than just huge jets? Do I need to modify the air bleeds? Maybe change accelerator pump?
I havent ran it past idle yet. But I know to the accelerator pump will cause a stumble if its not good enough for my setup.
Any carb tuning tips would be greatly appreciated. I do have a vacuum gauge and know that trick to setting the air bleeds. But I have had them all over the pkace with no avail. I also am running a steady 5-6 psi. And the pressure doesnt drop at all so I would think my pump is ok.
Here is an idle video if anyone is curious.
Old May 14, 2013 | 08:56 PM
onebadvert's Avatar
No carb guys or anyone used to tuning super high lift cams eh?
Old May 15, 2013 | 12:28 AM
Fox85's Avatar
I'd play around with your timing to start off. Then maybe make adjustments to the carb. What's your fuel pressure?
Old May 15, 2013 | 03:00 AM
91notchback's Avatar
I think it's gonna be hard to find someone with experience in a cam with over .600 lift Dream!!!lmao
Old May 15, 2013 | 03:51 AM
onebadvert's Avatar
15* initial 36* total
6-7 psi.
I have played with timing and fuek pressure to no avail.
I wondering if I need a vacuum canister to help pull fuel?
Right? Lol
Old May 15, 2013 | 09:46 AM
skunk21's Avatar
make sure you don't have a vacuum leak.
Old May 15, 2013 | 09:50 AM
onebadvert's Avatar
Funny. Cause I actually just called holley to verify my setup is up to the task. They said I shouldnt have any issues and to check for a vacuum leak.
Old May 15, 2013 | 09:56 AM
skunk21's Avatar
yeah a nasty vacuum leak can cause a problem, both lean and rich conditions can get the headers to glow. you figured out it was lean. check for things like timing that is too retarted ( verify timing marks/pointer are marked correct ), vacuum leak(s) etc.
Old May 15, 2013 | 10:05 AM
onebadvert's Avatar
I also have a high idle. Which is another reason the vacuum leak makes sense. Now I just need to track it down.
I know my timing, fuel pressure, etc are all good. So hopefully I can find the leak. Ill get some propane and start spraying suspect areas.
Old May 15, 2013 | 05:53 PM
Fox85's Avatar
Check all vacuum lines. And try replacing your map sensor out
Old May 15, 2013 | 05:58 PM
onebadvert's Avatar
No map sensor. Im running a carb with no ecu. I did find a vacuum leak but haven't had time to try and re tune it.
wallace
Mar 29, 2016 10:09 AM
Bryanh24
Oct 14, 2015 08:43 AM
Sep 30, 2015 07:02 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
