Blower to carb bonnet hookup???
Old Dec 16, 2010 | 06:46 PM
FordFan87's Avatar
Im in the process of converting my car from efi to carbureted and i am almost done except for hooking the blower to the carb bonnet. The pipe that is on there origionally ran to the throttle body but i cant use it now. I am needing a pipe that will go from the blower to the carb bonnet that has a spot for my blow off valve. I have searched everywhere with no luck. Has anyone ever done this or know where i can get the pipe that i need? Any help is greatly appreciated! Thanks, Adam
Old Dec 18, 2010 | 04:48 AM
lxlaw's Avatar
Why can't you use yours? Can't you turn the bonnet a bit more and use a bigger silicon coupled?
Old Dec 18, 2010 | 01:21 PM
FordFan87's Avatar
Well inside the bonnet is a blade that goes through the middle. If i try to put it at the 9 oclock position the divider hits the 2 overflow tubes sticking out the top of the carb. The way you are describing was the way i planned to do it until i ran into this issue.
Old Dec 18, 2010 | 03:54 PM
lxlaw's Avatar
Can it be modified with grinding?
Old Dec 18, 2010 | 05:06 PM
FordFan87's Avatar
Im sure it could and ive contemplated doing that but i just hate to go grinding on something i just spent $200 on. Lol..... But i may just have to do that.
Old Dec 18, 2010 | 07:29 PM
lxlaw's Avatar
it is hot rodding, it is meant to be upgraded!! Get the grinder out and make it work. You are going to spend more than that trying to find a fabbed pipe.
Old Dec 18, 2010 | 10:45 PM
FordFan87's Avatar
And i think you are right. Thats probably what ill end up doing. Thanks for the advise.
FromZto5
Sep 30, 2015 05:28 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
MrSylphie
Aug 18, 2015 08:40 PM
bob724
Aug 17, 2015 04:05 AM
