Blower to carb bonnet hookup???
Im in the process of converting my car from efi to carbureted and i am almost done except for hooking the blower to the carb bonnet. The pipe that is on there origionally ran to the throttle body but i cant use it now. I am needing a pipe that will go from the blower to the carb bonnet that has a spot for my blow off valve. I have searched everywhere with no luck. Has anyone ever done this or know where i can get the pipe that i need? Any help is greatly appreciated! Thanks, Adam
Well inside the bonnet is a blade that goes through the middle. If i try to put it at the 9 oclock position the divider hits the 2 overflow tubes sticking out the top of the carb. The way you are describing was the way i planned to do it until i ran into this issue.
FromZto5
Sep 30, 2015 05:28 AM
MrSylphie
Aug 18, 2015 08:40 PM
