Blinkers stopped working
Old Mar 17, 2011 | 10:44 AM
5.0 fReD's Avatar
(1990 5.0 GT)
Both side turn signals won't blink. They will only stay on. I checked all the fuses under the sterring wheel already and their good. Hazard lights work fine tho. Please help. I'm tired of having to signal manually lol
Old Mar 17, 2011 | 10:47 AM
BoogieNights's Avatar
BoogieNights Studios:
Official Fluffer
Have you looked at the blinker relay??
If not it is a silver tube like thing that should plug in around the fuse box. When that usually goes out thats what normally happens with the blinkers. There shoudl be 2 of them one for your normal blinkers and the other for your hazards.
Old Mar 17, 2011 | 11:11 AM
5.0 fReD's Avatar
I switched one of them. The one closest to the bottom and it didn't fix it
Old Mar 17, 2011 | 11:23 AM
Official Fluffer
Did you try switching it to the other one to see if it would fix it?? You could have changed the one for the emergancy flashers
can you switch them with each other and see what happens?
Old Mar 17, 2011 | 11:59 AM
5.0 fReD's Avatar
Thanx guys that didn't even cross my mind haha. Let me try it.
Old Mar 17, 2011 | 12:13 PM
Dread53's Avatar
I'm sorry, but I just can't resist asking if you checked the level on your blinker fluid....
Old Mar 17, 2011 | 01:39 PM
5.0 fReD's Avatar
Nah. Your the only person that checks the blinker fluid level.
Old Mar 17, 2011 | 02:03 PM
Redbaron93's Avatar
Check to see if you have any bulbs out. It has been my experience that when the blinker light stays on it's usually a blown bulb.
Old Mar 18, 2011 | 08:16 AM
HOSS429's Avatar
legacy Tms Member
if you know someone who has a similar car that they do work on listen to them blinking and find the relay that will be " tinking " as they " blinking "
Old Mar 19, 2011 | 01:48 PM
jacostang's Avatar
It might be module on the column, its very easy to replace, its the whole turn signal arm and if its not the flasher its that...
Mpaps
Oct 11, 2017 08:06 PM
Fords4Ever
Oct 30, 2015 09:07 PM
M3hunter
Sep 10, 2015 09:26 AM
BavarianStang
Sep 5, 2015 05:55 AM
retiredf5
Ecoboost
Jul 21, 2015 05:54 PM
