Backfire, spit, and sputter...
Old Aug 12, 2012 | 01:14 PM
91notchback's Avatar
When idling, my car backfires out of the throttle. When you give it gas, it stalls for a minute before gaining rpms. I've set timing a few times with spout connecter out. When I set it to 12 degrees btdc and put connector back in it goes way past that (larger number btdc.) Plugs are new and gapped at Ford specs (.054). Wires also new. I've checked fuel pressures and replaced a couple of lines with kinks, but problem still exists. Any help or suggestions would be greatly appreciated!
Old Aug 12, 2012 | 08:04 PM
onebadvert's Avatar
it will go up when its plugged back in that normal. but you should have the car off when plugging and unplugging the spout
Old Aug 13, 2012 | 07:47 AM
Is it possible that I am not getting enough spark from ignition coil, and it needs to be replaced? Just a rookie grabbing at straws here...
Old Aug 13, 2012 | 12:25 PM
onebadvert's Avatar
its definitly possible you have a weak coil.
Old Aug 17, 2012 | 02:01 PM
otmshank's Avatar
Things I would do:
1. Pull codes and post any/all you get
2. Check for a vacuum leak
3. Set the timing back to stock
Is the car modded in any way, other than timing? I'd recommend against guessing and throwing parts at the problem.
Old Aug 17, 2012 | 02:51 PM
AlsCobra's Avatar
A Man Just Needs Some....
Pull the distributor cap and check for moisture or and tracking marks where fire can be jumping across the cap.
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
tukatz
Aug 26, 2015 02:06 PM
FarmAnimal
Aug 3, 2015 05:53 PM
pilatti1
Apr 5, 2008 12:11 PM
92lx5.0
Mar 22, 2007 05:36 PM
