anybody know where to get a complete crate engine
Old May 28, 2005 | 10:14 PM
luvthe440Aroush's Avatar
[B][FONT=Arial][SIZE=14]
i'm looking for a completed motor for under $5500 thats has about 380-415 horse power
can anyone help me???
Old May 29, 2005 | 01:09 PM
Fordracing200's Avatar
www.ebaymotors.com
I checked FRPP and cant seem to fin dfull motors, why do u want a complete? why dont u just get a new short block an duse prts of your current motor for it?
Old May 31, 2005 | 02:14 PM
88blueGT's Avatar
Keith Craft. Here are some motors that are in your price range.
331/347 econo crate engine
425hp
415 ft. lbs. of torque
$5,295.00
Description: Fully machined production block, Scat cast steel crank, Scat I beam or Eagle rods, Mahle coated or SRP forged pistons, plasma moly rings, Hyd. Roller camshaft, double roller timing set, hyd roller lifters, Comp cams pushrods, Scorpion roller rockers, ARP fasteners, Fel Pro gasket, AFR 165 heads or cnc'd Brodix 5.0 Heads, Edelbrock Performer RPM intake, Production oil pan, BHJ replacement damper, 28oz. Balanced, Blueprinted and assembled.
or
408/410 econo crate engine
500hp
500 ft. lbs. of torque
$5,695.00
Description: Fully machined production block. Scat cast steel crank, Scat H beam or Eagle rods, Mahle coated or SRP Forged pistons, Plasma moly rings, Federal Mogul bearings, 28 oz. Balanced, Comp Cams hyd roller camshaft, double roller timing set, front cover, Melling oil pump, stock replacement oil pan, BHJ replacement damper, FORD racing hyd. Roller lifters, Comp Cams push rods, Scorpion roller rockers, ARP head bolts, AFR 185 heads or Brodix Track 1 heads, Fel Pro gasket set, Edelbrock Performer RPM intake, engine is Balanced, Blueprinted and assembled.
All depends on what size motors you want to go with. Keith Craft has alot of options. Or you can have them just build you a motor. The link that has most of the crate motors is http://keithcraft.com/ads/index.html. Check them out. Good luck.
Old May 31, 2005 | 02:59 PM
wow, what about Kuntz?
Feb 10, 2017 07:12 PM
FromZto5
Sep 30, 2015 05:28 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
Sep 16, 2015 06:44 PM
Evil_Capri
Sep 11, 2015 08:39 AM
