Another dumb one to ask.,,
Old Nov 14, 2013 | 08:18 PM
Lando's Avatar
But hey thats what i do! So i pretty much need to take my heads off and see if i have a burnt valve or a gasket issue. Can i take my (aluminum heads gtx40) heads off and then just bolt them down and go or i need to set timing adjust valves or what? Im not very familiar with the valvetrain and timing. I took my intake out and cleaned for new gasket but need to take heads off now. Please retard oriented instruccions are welcome. Thanks
Old Nov 15, 2013 | 04:39 PM
2 Go Snake's Avatar
Cool
The valves are most likely OK. The head gaskets could be bad. Just make sure you have a good torque wrench and torque the head bolts to the specs your head manufacturer recommends. Replace the head gaskets with Teflon coated head gaskets. Aluminum heads expand at a different rate than the cast iron block and need the Teflon gaskets. Did the previous owner torque the head bolts to specs ?
Old Nov 15, 2013 | 06:37 PM
take a compression test first
Old Nov 16, 2013 | 02:37 PM
Lando's Avatar
Thank you guys, i did a comp test and all cylinders are good and very very close in numbers. Also the intake manifold gasket came in today and i am not sure about tis two little extra gasket parts? Where do they go? Do they need to be in there? Why 4 when i can see only two places where they might go? Thanks
Old Nov 16, 2013 | 06:52 PM
BlueFox's Avatar
Im thinking if all the ports are even, and one is slightly different, maybe its a shim to make up the difference? Just guessing. Send a pic of the intake manifold if ya got one
Old Nov 18, 2013 | 12:15 PM
LivinTheStangLife's Avatar
Almost looks like the cross looking section in the middle is where they go. Sort of looks like you can either have a hole their in some intakes and not in others possibly
Old Nov 19, 2013 | 10:44 AM
2 Go Snake's Avatar
I think LivinTheStangLife is correct. The small piece of gasket with the whole in it would be used if you had a street head and wanted heat to flow into the intake to warm the carburetor more quickly. If you wanted to block off the heat to the carb in race applications , you would use the solid piece to cover the whole in the head below the cross part of the head gasket. Heads designed for racing often do not have a hole in the head under the cross part of the intake gasket and probably would not require either one of the small pieces in your picture.
Old Nov 19, 2013 | 03:33 PM
Lando's Avatar
Thank you guys. Manifold installed with solid piece and no issues, and no vacuum leaks runs like a beast. Tha k you guys.
Old Nov 20, 2013 | 12:17 PM
2 Go Snake's Avatar
Question
Good to hear your Mustang is running so strong. I like the intake gasket you installed. What brand is it ?
ricky1728
Feb 11, 2016 07:25 PM
Fernando.4ohh
Sep 10, 2015 03:35 PM
andy21996
Ecoboost
Aug 27, 2015 01:43 PM
Warrior316
Jul 22, 2015 02:38 PM
