89 5.0HO efi to carb
Old Sep 29, 2006 | 06:02 PM
jawsh569's Avatar
Hi,
This is my first time posting. I have been searching all over for information on taking an 89 5.0HO and building it carburated...For one is this possible? And another which type of ignition system will work with an 89 block? Another is if this is possible...which combination of Edelbrock inake and carb would work...If anyone has any information that would be great..or any links that would help me out...
Old Sep 30, 2006 | 07:05 AM
svopaul's Avatar
Service Manager
Originally Posted by jawsh569
Hi,
Sure it's possible but WHY?!? You are going backwards by doing that conversion.
You would have to change the fuel lines, fuel tank, change the distributor, modify the wiring harness, change timing cover or run an electric lower pressure fuel pump, etc, etc.
Old Jan 6, 2007 | 09:58 PM
jawsh569's Avatar
I understand I'd have to change fuel lines, gas tank etc....Actually the block is out of an 89 Mustang GT but the engine is going into a 91 Ford Ranger. So you can see I already have alot of work going into this.
Old Jan 8, 2007 | 08:00 AM
svopaul's Avatar
Service Manager
You didn't specify that it was going in a ranger....and since this is a Mustang forum it was assumed you were working on a Mustang.
An engine is an engine...ignition system pretty generic, just buy all the carb related parts...intake, distributor etc and go from there. That swap has been done about a thousand times so I am sure that someone out there on the web has the swap detailed on a web site somewhere.
Old Jan 8, 2007 | 05:07 PM
jawsh569's Avatar
I know I didn't specify that it was going into a ranger. And yes I know this is a Mustang forum, but I figured this would be the best source for anything on an engine that came out of a mustang
Old Jan 8, 2007 | 05:24 PM
karman's Avatar
Here's some info if you don't have it already:
http://www.therangerstation.com/tech...nversions.html
http://sleepinranger.com/Home/home.htm
http://www.jamesduff.com/broncoII/v8conversion.html
MrSylphie
Aug 18, 2015 08:40 PM
luvthe440Aroush
Sep 12, 2005 02:38 PM
BLAKE
Sep 13, 2004 05:06 PM
Fishhawk
Jul 3, 2004 12:14 PM
lordshwa
Jun 15, 2004 11:40 AM
