87 5.0gt no power to fuel pump
Old Apr 30, 2013 | 06:00 PM
mannybrown1976's Avatar
I need help! I'm not getting power to the fuel pump. Replaced fuel pump relay and still no better. What else could it be or what else should I check? Thanks for suggestions...
Old Apr 30, 2013 | 06:21 PM
tom281's Avatar
Does your car have the inertia switch in the trunk? Are you sure you swapped the correct relay, I believe there is another relay in close proximity that cuts the a/c at wot. Did you read the thread stickied here for no start issues?
Old Apr 30, 2013 | 07:08 PM
Will have to check for inertia switch... Not sure. I am new to this group. Where do I find the stickies thread for no start issues?
Old Apr 30, 2013 | 08:21 PM
tom281's Avatar
The switch is on the drivers side of the car on the rear panel of the car by the tail light. The thread you want is right here in this sticky list it is called fox tech.
Rando
Aug 25, 2021 11:12 AM
RCooke08GT
Feb 19, 2017 03:03 AM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
