5 or 6 speed
Old Sep 11, 2009 | 10:08 PM
greengt88's Avatar
5 or 6 speed
So it's time to upgrade from the tired t-5, I'm really looking to build this car for top-end performance. What am i betteer off going with? How well does the T-56 or the new T-56 Magnum for that matter, fit into a fox? Is the extra gear worth it? or should i get a tko 500/600 instead. It's a big dollar purchase and i don't want to be disappointed after i do. Any opinions would be greatly appreciated.
Old Sep 11, 2009 | 10:18 PM
future9er24's Avatar
i cant give any preferences but the T56 will for sure fit in the fox. you'll need either a special belhousing or adapter plate though.
also, I've heard good things about the magnum..
Old Sep 12, 2009 | 12:51 AM
cntchds's Avatar
The Magnum is basically a T-56 shell with T6060 internals. Like Arin said, you'll need a bellhousing, but other than that and getting a shortened driveshaft, you should be good to go.
Old Sep 12, 2009 | 10:37 AM
hi5.0's Avatar
Think you may need to look into either modifying or getting a specific rear mount for that application if not included. Definitely should get away from the weaksauce 10-spline input shaft. IIRC, versions like the Corvette/Viper-spec T-56 have at least 26-spline ones. Of course this means changing the clutch to match as well.
Old Sep 12, 2009 | 02:14 PM
bluethunderhorse's Avatar
Here's a whole kit in one box
http://www.ddperformance.com/shop/in...p?cPath=108_96
Old Sep 12, 2009 | 02:33 PM
i really hope i have the money for a magnum someday... sigh
Old Sep 13, 2009 | 01:31 AM
cntchds's Avatar
It's weird that the Viper Spec T-56 is more expensive than the Magnum... I wonder what the differences are exactly. Arin swears to me that the gears in the Viper spec are "not what a Mustang needs." Peter say- If it's good enough for a Viper, it's good enough for me. It just means that the car needs a V-10.
Old Sep 13, 2009 | 01:36 PM
I've read alot of threads saying that the way the gears are spaced out do not feel good in our cars. I'll take the magnum 8 days a week
Peter is just dumb because he lusts after a Viper and would be happy just saying "oh its viper spec" all the time
Old Sep 13, 2009 | 06:07 PM
greengt88's Avatar
keep in mind that i'm trying to go 200mph, so that viper spec gearing is probably what i'm looking for, i asked the same question on another site and general concensus was viper spec t-56 w/ a 26-spline input and quicktime bellhousing, or the new magnum with correct gear set. does anyone make a good application specific crossmember? i remember hpm and kenny brown both used to make one, curious if they are compatible with the magnum
Old Sep 13, 2009 | 08:03 PM
The kit I posted, post #5 has the transmission, cross member, speedo cable, and drive shaft you can either get the magnum or the viper spec trans
Old Oct 2, 2009 | 12:01 AM
DrunkenDragon713's Avatar
I've heard a lot of good things about these transmissions. I plan on building an 89 GT (can't decide on a hatchback or a notch) and will be using the magnum matched with "T and L" direct replacement 347 Stroker Engine. I'm about 80% sure that they will match up.
CiniZter
25
Apr 28, 2016 05:41 PM
blackhawkkid308
1994-2004 V-8
18
Dec 22, 2015 03:17 AM
robjh22
Dec 14, 2015 08:41 AM
Sep 8, 2015 10:45 AM
