5.0: Mild Mods
Here's a list of some basics that I plan on doing for my 5.0 this summer, once I get outta college.
3 point strut brace (fenders & firewall mounts)
G Load/Kmember brace
Remove air silencer
K&N air filter
Replace spark plugs/wires/cap/rotor
65mm throttle body
GT-40/Cobra intake manifold
H-pipe
Welded subframe connectors
Going to redo the exhaust as well, but first I need to hear a few of them in person before I make my decision. Since I have a vert', I'm going to be hearing the exhaust a lot, so I've gotta make a good choice.
My question is:
Underdrive pulleys rob power from the alternator, power steering, water pump, etc. Will installing them on my car give me problems down the road? I worry about my alternator because:
1) My car is a convertable and I'm sure the drop-top takes loads of power to run.
2) I have a 1500 watt stereo system.
Also, any other cheap, DIY jobs I should add to my list?
Thanks in advance,
Mike
Remove air silencer
K&N air filter
65mm throttle body
H-pipe
My question is:
Thanks in advance,
Mike
Get a bigger alternator!! 130amp
Sounds sweet, have a good time this summer. I am a sucker for flowmasters on a 5.0. (Had them on all my 5.0 Capris.)
Also, maybe a shifter if you don't already have one.
Anyone know of any good tail lights out there for foxes? Right now I've got the standard ones... I'm not a big fan of the GT slotted ones, or the Cobra ones, or the altezza ones... Are there any other options as far as tail lights go?
Yeah... they're probably what I'm gonna stick with. I dunno, I think tri-bar vertical lights would look pretty nice on the fox, but I don't think there's any out there...
Speaking of Taillights, does anybody know of a place that sells the GT "cheesegrader" light covers...my passenger's side is chiped right at the corner. Can you get them pre-painted need a twilightblue one. I know they're hard to find.
I just picked up a pair of 82 taillights (5 vertical lights) at a yard. Gonna see if I can't hack em' up a little.
Gonna see what I can do with those... I'll remove the two inner red lights and replace them with flat black plastic. I think there's gonna be too much blank space when I'm done, but, heck, it's worth a shot.
As for the cheesegraters, you could try the usuals: junkyard, 5.0 resto, or ebay. I'm sure one of those three would have what you're lookin' for.
If I were you I just wouldnt get the pulleys all together. When I put mine on I had nothing but problems after that. They were like a jinx. And if you want a nice exhaust I would go with some MAC Headers w/ a MAC H pipe. It will sound loud but not too loud (considering you have a vert) and when you get on it they will have a nice tone to them.
The GT light covers are hard to find, i managed to luck out and find one on ebay other than that i dont know where u would be able to find one
