351W in FOX
Old Jan 1, 2010 | 11:37 AM
kennyg's Avatar
351W in FOX
Anyone put a 351W in a FOX? What headers will fit? kennyg
Old Jan 1, 2010 | 06:56 PM
dcpirani's Avatar
BBK make headers for a 351 swap. Part #1511 shorty and #1569 long tube. I'm sure others make them also.
Old Jan 1, 2010 | 07:03 PM
BoogieNights's Avatar
BoogieNights Studios:
Official Fluffer
I know Kooks headers makes a set for a 460 that has 4 seperate pipes going into a single collector that you can install without removing the steering rod and dont have to make any "adjustments" to the frame or headers themselves.
Old Jan 2, 2010 | 08:07 AM
bob's Avatar
bob
Thats a pretty common swap, I beleive at one point FRPP sold a swap kit as well (accesory brackets, oil pan, ect).
Old Jan 3, 2010 | 12:19 AM
DynamicmustangGT's Avatar
http://www.ddautospec.com/products_e...wap.html#jump1 these guys have multiple kits
Old Jan 3, 2010 | 11:46 AM
kennyg's Avatar
Originally Posted by DynamicmustangGT
Their basic kit with mounts, pan, and headers is $430. Not too bad. Thanks for the info. Whats the HP gain with long tube headers vs shorties? kennyg
Old Jan 3, 2010 | 06:18 PM
I would think top end plus 25-30hp but low end might be less so than shorties, based on the 05's comparisons
Old Jan 3, 2010 | 06:19 PM
That is compared to stock manifolds btw
Old Jan 3, 2010 | 06:57 PM
GT5088's Avatar
the swap shouldn't be too bad, the problems come into play with the cleveland 351 block
Old Jan 21, 2010 | 03:52 AM
They offer a kit for the clevland as well.
Old Jan 21, 2010 | 09:12 PM
GT5088's Avatar
I imagine they do, I just would think that swapping in a windsor would be easier than a cleveland due to the deck width
Old Jan 21, 2010 | 10:17 PM
Yeah it might be tight but I'd rather have a clevland over a Windsor anyday.
Old Jan 21, 2010 | 11:19 PM
bob's Avatar
bob
I'd go for a Clevor myself, you get the goodness of the windsor block with the awesomeness of a canted valve cylinderhead.
I'm not a fan of the stock Ford cleveland heads, but the aftermarket has produced some excellent stuff. Then again even the in-line valve stuff flows a stupid amount of air (AFR has a big port cylinderhead that flows 320 cfm on a 4-1/8" bore) the latter of which opens up alot of intake manifold choices in both carb and injection.
Old Jan 21, 2010 | 11:54 PM
Could get some boss351/351 NASCAR heads. Should add some nasty airflow.
Autotooner
Nov 24, 2017 12:42 PM
JTB
Motorsports
Oct 29, 2015 09:07 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
JTB
Motorsports
Sep 7, 2015 10:20 PM
