2.3 sputtering
Old Mar 3, 2014 | 08:20 PM
TR3V0R924's Avatar
2.3 sputtering
My 1991 dual ignition sputters when it's warm. It hasn't been properly warming up but I know why. But when it sits while running and runs warmer it will sputter in 2nd and 3rd gear. And in all other gears at high rpms. It's a manual. I feel like it's smog or something screwing it up but anything you guys might know?
Old Mar 4, 2014 | 06:03 AM
When was the last time it had a tune up? I would start there. Fuel filter included
Old Mar 4, 2014 | 01:02 PM
When my F150 starts acting up like that I run a tank of Regane and it clears right up.
Maybe its something as easy for your engine.
Old Mar 4, 2014 | 01:24 PM
TR3V0R924's Avatar
I went through and replaced plugs and plug wires. I have a fuel filter just need to put it on. I'll get some of the stuff and run it through. It just does it when it's warm which I find is weird.
Old Mar 4, 2014 | 05:15 PM
My guess would be not getting enough spark/timing is off or not enough fuel...of course I'm just guessing through the interweb.
How many miles are on it? Have you done a compression test lately/ever?
Old Mar 4, 2014 | 11:32 PM
TR3V0R924's Avatar
The odometer says 38k but it doesn't have a hundred thousands place so it's safe to assume 138k. I haven't done a compression test ever. I went to autozone. I asked the guy there. He said clean the MAF and I got some of that fuel system cleaner and I also got some stuff that is supposed to seal the cylinders to fix any slight compression leaks. I also picked up some paint thinner to get the God awful camo paint the last guy put on the car. I'm 18 an I've owned 4 cars since I was 16. My first car was nearly exactly the same as this car just a 1990 and there is soooo much different. I mean I didn't have a MAF on that mustang.
Old Mar 6, 2014 | 09:03 PM
TR3V0R924's Avatar
I cleaned the MAF. It has helped. Hasn't cured it. It happens less frequently and less violently. So I'll go and clean all the other air sensors.
Old Mar 9, 2014 | 06:52 PM
The Mad Dooby's Avatar
Hey, just a note on the paint thinner. Try using oven cleaner too. I use Easy Off oven cleaner. You can get it from Wal-Mart. As for the motor... Sounds like it could be an injector or fuel related problem.
pats67copo
Repair & Service Help
17
Nov 5, 2025 07:43 AM
Evil_Capri
Sep 25, 2015 12:56 PM
tomsorangemustang
1994-2004 V-6
Apr 14, 2011 03:26 PM
UMich97
Mar 9, 2011 12:58 PM
K_cobra
1994-2004 V-8
Jan 29, 2008 02:05 PM
