1993 cobra upper intake manifold lines
Old Oct 24, 2016 | 05:12 PM
Joey81's Avatar
I need a little assistance. I have what I think to be a missing vacuum hose or line on my upper intake manifold. When looking at it from the front of the car moving left, right before the throttle body, I have a capped off vacuum nipple. Any one have any idea where that hooks up to?
Old Oct 25, 2016 | 07:02 AM
https://www.searchlock.com/search?sa...manifold+lines
will any of these help?
Old Oct 25, 2016 | 10:43 AM
ALMOST STOCK's Avatar
Do you still have your Charcoal Canister or has it been eliminated, if you still have your charcoal canister then you need to move the vacuum line that ran out from the bottom of your old stock upper intake manifold and plug it into that port.
Attached Thumbnails 1993 cobra upper intake manifold lines-line-charcoal-canister.jpg
Old Oct 25, 2016 | 12:18 PM
Joey81's Avatar
That photo is the port I was talking about . I will have to check If the previous owner removed the charcoal canister or not .. thanks for the help.. this car is a vacuum hose nightmare
Old Oct 25, 2016 | 12:22 PM
Joey81's Avatar
One more question .. what about the vacuum
line for the Map sensor?
Old Oct 25, 2016 | 03:38 PM
This should help.
Attached Thumbnails 1993 cobra upper intake manifold lines-use-without-t.jpg
Old Oct 25, 2016 | 08:30 PM
Joey81's Avatar
Is that correct
