1988 mustang gt idle help
Old Apr 29, 2008 | 12:09 AM
nice88gt's Avatar
hello i have a 88 gt 5.0l high output. when i start my car cold it idles fine but when i start it warm it idles real low and sometimes stalls. iam just wondering what is wrong. my buddy thinks its something to do with the vac but i don,t know........... anyone
Old Apr 29, 2008 | 02:10 AM
future9er24's Avatar
If its only happening during warm days it might be cooling related
Old Apr 29, 2008 | 06:01 PM
nice88gt's Avatar
sorry i ment to say it only happens when i start my car within a hour of driving it. the weather has no effect on my idle what so ever its just when my car is warm from driving it one guy says vac leak
another guy says cloged mass air flow sensor
Old Apr 29, 2008 | 06:19 PM
hmm thats interesting. I've never heard of a problem like that before.
I wish i could help more I'm sure someone here will be able to help though
Old Apr 29, 2008 | 07:10 PM
GT5088's Avatar
right near your throttle body there is a sensor with a metal piece that usually is dirty...maybe it is called the mass air flow sensor. I had the same problem, and I took the metal piece off and cleaned i with carb cleaner, dried it off, then put it back together...problem solved...I just forget off the top of my head as to where precisely it is...I think it may be right near the throttle positioning sensor..
If it only happens when you first turn the car on, I doubt its a vacuum leak...but I'm no mechanic
Old Apr 30, 2008 | 06:43 AM
x21's Avatar
x21
Assuming the 88 Mustang he has is not from california, and also if the previous owners have not done a swap, there should not be a mass air low sensor on that engine. However, if it indeed does have a MAF sensor, then make sure you know how to properly clean it. The idle- when you say it goes lower than normal, is it also rough? or still smooth, but just at a lower RPM? And also, could you give us the rpm range it falls down to and whats "normal" for you?
Old May 1, 2008 | 02:18 PM
jacostang's Avatar
Could be the TPS going out or cruddy? Throttle Position Sensor right on top of the Throttle Body. Mine did that on my 87 a whilke ago...
Old May 1, 2008 | 02:50 PM
GT5088's Avatar
Sometimes it can be the position of the TPS...if it somehow moved from the angle it was at before that can affect it as well..
Old May 1, 2008 | 06:07 PM
nice88gt's Avatar
my car idles just under 1000 rpm normal. but when it idles lower its 500 rpm and it goes from 500 to 900 rpm back and forth . it runs smooth with the lower idle and it does not have a mass air flow sensor thx
Old May 4, 2008 | 10:12 PM
nice88gt's Avatar
thx for the help but i figured it out it now runs fine no probs
Old May 4, 2008 | 10:53 PM
Valentino's Avatar
so what was it?
Old May 5, 2008 | 04:42 AM
touring's Avatar
Originally Posted by Valentino
so what was it?
what was it?
Old May 5, 2008 | 05:54 AM
red pony's Avatar
It must have been the Idle Air Bypass Valve mounted next to the throttle body. They plug up with crud and need to be cleaned with carb cleaner from time to time. You take it off and flush out the ports and valve and put it back on. If that doesn't clear it up right , replace it.
Old May 5, 2008 | 09:12 AM
GT5088's Avatar
well, at least its solved
Old May 5, 2008 | 05:40 PM
Valentino's Avatar
he still hasn't said what the problem was
Old May 5, 2008 | 06:01 PM
GT5088's Avatar
hmmmm
Old May 5, 2008 | 06:06 PM
nice88gt's Avatar
Talking
ok first i bought a new TPS and no go.then i took the mustang to work and changed my alt still no go.then i changed my injectors/my boss guessed right it was the injectors
and now it runs like a dream
but anyways thx for the help everyone
and sorry for taking so long to tell u guys what the prob was
Old May 5, 2008 | 06:08 PM
GT5088's Avatar
did you go with 19 pound injectors, or heavier?
Old May 5, 2008 | 08:05 PM
nice88gt's Avatar
i just stuck with the stock 19lb injectors
Old May 7, 2008 | 11:58 PM
jacostang's Avatar
Glad it worked out for ya!!
Jim74656
May 1, 2023 02:15 AM
Jul 20, 2015 06:26 AM
dohc97
Jul 19, 2015 07:29 PM
goocher625
1994-2004 V-8
Jul 15, 2015 08:08 AM
