Whats a stock rear end on a '65?
Old Oct 31, 2005 | 10:13 AM
codeman94's Avatar
Hey...this may be a silly question, but what is the rearend on a '65 coupe, assuming its stock...which I belive it is....I wanna add traction lock, but need to know what I got...also, any body know a good way to get posi traction? should i get a Spool? help me out so I can get some added performance and leave two (2) black lines on the road!!
Old Nov 2, 2005 | 11:57 AM
gjz30075's Avatar
Need to know if your car is a 6 or 8 cyl. Two different rear ends with each car. Best way to tell is to look at the diff. If it has studs and nuts around the front of the rear, then its an 8". If it has bolts around the back of the diff, then its the weaker 7 1/4" weaker rear end.
Old Nov 4, 2005 | 08:42 AM
codeman94's Avatar
Its 289...and how do you tell the difference between studs and bolts? Are the nuts what I'm looking for?
Old Nov 6, 2005 | 08:02 AM
gjz30075's Avatar
A bolt will have no threads showing above the head. A stud will have a nut on it and have threads showing. Either way, if the attachment points are in the front, its an 8"/9" if they are in the rear, then its the smaller 7 1/4".
Old Nov 6, 2005 | 08:35 AM
codeman94's Avatar
ok...thatnks a lot
Ecostang
Nov 3, 2022 08:50 PM
chadh92
Jul 29, 2015 06:56 AM
Kev006
Jul 8, 2015 05:29 AM
