Water un the transmission
Old Oct 18, 2012 | 03:05 PM
mustang-68's Avatar
I have a 68 mustang with a c4 transmission I got the transmission with the car I have done 3 transmission services and there still water in it and help with help thanx
Old Oct 18, 2012 | 04:56 PM
Womprat's Avatar
Filler tube seated?
Old Oct 19, 2012 | 02:07 PM
mustang-68's Avatar
Yea it is
Old Oct 22, 2012 | 10:26 AM
koolmotor's Avatar
I'm new to the forum and know very little about Mustangs, but is there by chance a transmission fluid cooler installed? I had problems on a much newer vehicle (Nissan truck) with seal failure allowing coolant to mix with the transmission fuid and vice versa (ended up getting a new tranny). Open up the radiator or drop the transmisison pan and it looks like a strawberry milkshake. Not likely I know, but I figured anything is possible...
Old Oct 23, 2012 | 12:08 AM
houtex's Avatar
possibly a bad seal on the input shaft of the transmission, where splashing water could maybe possibly get in it that way? No, that's silly, it'd leak out transmission fluid there if that were the case...
Other than that... and the filler tube... and possibly the speedo gear orifice... not real sure how in the world you'd get water in it without also seeing leaks...?
Old Oct 24, 2012 | 03:37 AM
RW1967GTA's Avatar
My thought on this would be an internal leak in your radiator. Transmission cooler lines run into the bottom of your radiator and the radiator acts like a cooler for your transmission fluid as well. There's a chance that there is an internal leak allowing the antifreeze / trans fluid to mix. Check your radiator water for evidence of trans fluid.
Hope that helps.
Old Oct 25, 2012 | 01:45 PM
mustang-68's Avatar
I put a brand new radiator in it and in transmission lines
Rando
Sep 30, 2015 12:28 PM
Mustang65bob
Sep 21, 2015 11:30 AM
Beouch
Sep 16, 2015 06:14 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
