"Virtual" EFI Swap - Part 2
Let's say that we're going to use MY car for an EFI swap. Feel free to post links to good sites, completed Ebay auctions, etc...
What do we need for a fuel pump?
One pump or two?
What are the options?
What are the costs?
What about surge tanks?
What about hoses / lines? Alternatives?
Fuel tank change required?
Are factory 5.0 fuel rails adequate?
What size fuel injectors?
What else do we need?
COSTS????
One pump or two?
What are the costs?
COSTS????
Upper and lower intake manifolds. Ensure they are complete.
Replacing everything but the fuel rails and throttle body.
Throttle body
Fuel rails
Fuel Injectors
Main wiring harness ($$$)
Distributor for new TFI
Ignition E-Coil
EEC-IV Computer ($$$)
Sensors & Actuators
Gas tank with return fuel line
Low pressure fuel pump
High pressure fuel pump
High pressure fuel line and filter
Exhaust with a way to mount O2 sensors in the exhaust stream.
Throttle body
Fuel rails
Fuel Injectors
Ignition E-Coil
Sensors & Actuators
Say that 3 times fast!
Tech article on fuel delivery. Apparently stock rails are good up to 450hp with an adjustable regulator and a larger pump and recommend 1/2 " braided steel fuel line. 3/4 down the page.
