Violent Jolt When Going From Park Into Drive Or Reverse
Old Jul 10, 2010 | 12:39 PM
Justin's Avatar
I have a 70 Mach 1, FMX auto transmission and there is a violent jolt when I go from Park into drive or reverse, it's worse when the car is warm, ie it doesn't happen when i'm reversing the car out of my garage, apart from that the gears shift great when driving, there is no knocking or delays when going through the gears, i've currently got the car booked in with a Mustang specialist as I had to have the carb rebuilt, but any ideas what the problem could be, do you think the transmission could need rebuilding? I sure hope not, we've got a new modulator valve on order as that is the cheapest option at the moment, thanks for any help
Old Jul 11, 2010 | 08:08 PM
ChrisM's Avatar
The first thing I'd do is check the fluid level. Do this when the fluid is hot and add as needed.
Old Jul 12, 2010 | 05:58 AM
could be several things for sure. As stated above fluid level. Time for a fluid and filter change. Tq coverter going south. Maybe drive shaft ujoints?<----that was my first thought
Mpaps
Oct 11, 2017 08:06 PM
Jul 8, 2016 08:53 AM
Fords4Ever
Oct 30, 2015 09:07 PM
Gabe
Sep 7, 2015 03:30 PM
2012Kona
Aug 21, 2015 08:36 AM
