tuning help
Old Apr 3, 2008 | 04:06 AM
big_block's Avatar
tuning help
hey guys my son is taking his 65 coupe to the track to do some time runs ,,the eng has been bored 30 over hes got a elect fan also
hes got a mild cam,, 4 bl carb and intake ,, we changed the auto tranny for a stock 4 speed stock rear end ,,,,, so what can i do for improvement ???
whats the best timming ?? advanced ??
whats the best carb setting ,, little more air or less
or anything else i can do ??
thanks hope to see a goot time
Old Apr 4, 2008 | 09:48 AM
big_block's Avatar
anyone ???? any ideas??
Old Apr 4, 2008 | 10:30 AM
Grell's Avatar
Too many variables to give any kind of suggestions. What carb, what intake, what gears, what elevation, what surface, what tires, 1/8 mile or 1/4 mile, what compression ratio, what cam? headers? equal legnth or non equal legnth. From your question I am guessing you have little experience. I am also guessing this is a first time adventure to the strip. This is assuming the word "track" means drag strip.
Why not just go, run the car, have some fun, if it does good fine if not who cares, just go have fun and see if you even like it or if you get on the staging and freak out. Dont expect this car to run 10 second times when in reality it could run 15' 16' or slower.
After that learn from it if you enjoy doing it. Then you can talk to others at your track and ask fro advice. No one on this forum can answer these questions without knowing your car and knowing your area.
One note I will add, most people who read your post, is going to come to the conclusion that daddy had alot of money and bought his bratty kid a car. And most car guys will not help out in that situation. This may or may not be the situation, but it does come across that way.
Please note I am not trying to be offensive or mean, just saying it as it is.
Old Apr 4, 2008 | 10:45 AM
x21's Avatar
x21
What size motor is it? If you havent already, step up to electronic ignition? Headers (long or shorties), exhaust setup? Rear gear- ratio, differential or limited slip, remember, Ford had several different rear ends. Going to run street tires or drag radials? Even having a K&N or other hi-flow filter element might help.
On a safety note, maybe getting a dual master cylinder and disc brakes.
Old Apr 4, 2008 | 02:41 PM
big_block's Avatar
ok sorry 289 bored 30 over k&n filter stock rear end ,, tri-y headers,,, street tires,, i know the time will be slow i guess we are hoping for high 15 or low 16 i say ,,, and no i din't buy the car , i only put my labor into it thats all he bought the car when he was 15 and worked and put everything into him self thats the best thing its all his and he will enjoy it,, the sad thing is i will be there to watch lol ,, anyay i am hoping nothing breaks
thanks guys
Old Apr 4, 2008 | 03:45 PM
x21's Avatar
x21
I had to ask being your sig says "big_block" (Even though I know it takes at least a sledgehammer to even get a 351 into a stock 65-66 bay)
To get you a baseline I found this:
"As for straight-line performance, R&T's 210-horsepower 289/four-speed car did about what the editors expected: 0-60 mph in nine seconds (vs. 11.2 for an automatic 260), a standing quarter-mile of 16.5 at 80 mph, 110 mph all out, and 14-18 mpg."
at http://auto.howstuffworks.com/1965-1...d-mustang4.htm
Old Apr 4, 2008 | 03:58 PM
hiznherponies's Avatar
Well, my advice is to get your son a helmet, even if the car runs in the 15's, and just go there and have FUN!! Take some tools to maybe tune it with, or if something breaks. Oh, and speaking about brakes, I'm echoing the upgrade to a dual master cylinder (I'm using one for a '69) and disc brakes, if you haven't already. BTW, I'm going to the track here in MI tomorrow, hopefully!!
Old Apr 5, 2008 | 04:08 AM
big_block's Avatar
ohhh it has power breaks and power steering also ,, i hope this is the last time we go to the track i want hin to just drive the car show it off and have fun with the people looking at it driving down the road you dont see many on the road anymore most people dont drive them just drive it and have fun ,, not draggin it but thats me old guy yuo know
thanks guys i'll let you what happens
Old Apr 5, 2008 | 04:21 AM
runningwild4.6's Avatar
Good luck and let us know how he does! As for what to do, just go and have fun! He may need to tweek timing, that all depends on track conditions. have fun and keep us posted
Old Apr 5, 2008 | 11:41 AM
x21's Avatar
x21
Oh there shouldnt be anything to fear about the track. I would much rather have someone go racing at a track than on public streets. Oh and this may be a little late, but welcome to the forum!
Old Apr 7, 2008 | 03:33 AM
big_block's Avatar
well everything went great at the track the first run he got into in and the time was 18 something it set there and spun on the second run he eased into it and got 15.5 ,, that what he wanted still had a lot wheel hope between 1st ad 2nd and 3rd and remeber the pig leg thing ,, so i think he is going to do diff lock and see what the ,, the tranny was smooth so i guess we did a good job on the swap from the auto ,,,, so over all a good day
Old Apr 7, 2008 | 11:12 AM
future9er24's Avatar
Not bad!
I'm a bit late, but welcome to The Mustang Source
also...
Old Apr 7, 2008 | 11:53 AM
red pony's Avatar
Your best timing : first, disconnect the vacuum line and plug it . Then set your timing @ 32 degrees before TDC @ 3000 RPM -- 30 degrees is fine. I say 3000 RPM'S because by then , the mechanical advance is fully advanced. This is good for dragstrip duty . Leave the vacuum line plugged while at the strip . For the street , re-connect the vacuum line, and set the timing with the line connected to 36 degrees BTDC @ 3000 RPM'S. This gives best throttle response and good over-all gas mileage. The dragstrip setting gives you more high RPM torque if you have even modest rear gears ( 3.25 -- 3.73 ) and helps keep the wheel-spin to a minimum at the line. Drag slicks help too .
The carb setting : For a 289 with the stock 9.8/1 compression ratio, mild cam , ( stock street cam, or up to 220 degree duration @ .050 lift cam ) a 600 CFM is quite sufficient . You don't want a double pumper on the street, it gets too thirsty ! Gas is too high for that ! But a good vacuum secondary 4 BBL set right is great . But my favorite carb for the street is the Carter AFB 600 CFM 4 BBL with automatic choke . Out of the box, it is jetted nicely for your application . Just set the idle mixture after it warms up , set the idle speed and it's set -and-forget . Holly carbs are not so forgiving .They may perform a little better, but are always needing a little fine tuning. To me , the AFB is the way to go . To set a carb : warm up the engine to operation temp . Set RPM's 150 RPM's below factory recommended setting and adjust idle mixture screws to highest RPM , ( first turn in, if it drops, turn out to highest RPM and stop ). Then set idle RPM as per recommendation . But MAKE SURE THE CHOKE IS WIDE OPEN before any adjustments Other than that, just enjoy it ! Red Pony .
wallace
Mar 29, 2016 10:09 AM
Bryanh24
Oct 14, 2015 08:43 AM
Sep 30, 2015 07:02 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
