transmission problems
Old Oct 25, 2004 | 03:01 PM
mongooztt's Avatar
I just fininished installing my rebuilt C4 and everything went smoothly. I got the car ready to start and realized it would roll in all gears and would not turn over. I crawled underneath and adjusted the shifter linkage. I got it to go into park, which allowed the neutral safety switch to let the starter turn over. Once I got the car to start, tuned it a little, I put it into reverse and it was still in neutral. The same for D, 2, and 1. It will go in and out of park, but it is like all other gears are in neutral. Do I need to adjust the linkage again? I am adjusting it at the shifter, where it is slotted. Does anyone know where it needs to be?
Old Oct 26, 2004 | 10:57 AM
mongooztt's Avatar
I guess everybody is too busy building an imaginary car to help people who have real problems with their real cars.
Old Oct 26, 2004 | 11:32 AM
jpony645's Avatar
Filled with fluid?......Converter too?
Bad valve body? Blockage?
There are a lot of possiblities and I'm no pro.
BTW, lighten up. Ever think that maybe noone that saw your post could answer?
Old Oct 26, 2004 | 11:56 AM
Mberglo's Avatar
Did you disassemble the valvebody? Did you make sure all the ***** got back in the right spots? If you didn't disassemble the valvebody, my next guess is that you didn't get the linkage positioned correctly when you reinstalled the valvebody. You have to get it in just right with respect to other levers and pistons. I would drop the pan, remove the valvebody, and check this area closely.
Old Oct 26, 2004 | 12:28 PM
Jay's Avatar
Jay
Great way to start I never understood the concept of insulting the people you are asking for help from...
Did you check the fluid level Junior? :geek:
Old Oct 27, 2004 | 12:12 AM
mongooztt's Avatar
I did check the fluid level. It's fine. I did not rebuild the transmission myself, I had a reputable shop do it as well as flush, check, and fill the converter. I did not mean to insult anyone, I am just used to a forum where there is a wealth of information and people are usually quick about responding with help. There are also no make believe car buildups, or at least they're not taken that seriously.
Junior
Old Oct 27, 2004 | 06:21 AM
Mberglo's Avatar
If it was built by a reputable shop, I know just what I'd do....call them.
Edit: I didn't realize you were messing with the shifter until I reread your post.
Put the car on jackstands, and disconnect the shifter linkage. Start the car in park. Crawl under the car and and activate the shifter linkage at the transmission. You may need someone sitting in the car to operate the brakes so you don't start slamming gears. If the tranny works that way, you've got something wrong with your shifter setup. If not, refer to step one.
Old Oct 27, 2004 | 06:47 AM
GT350Clone's Avatar
My thoughts EXACTLY.
Nearly impossible for those of us who can not see, hear, or feel what it is doing to diagnose the problem... :nono: I would guess that the internal linkage was not done correctly when the valvebody was installed. I've never had any luck getting the torque convertor more than 1/2 "pre-filled" either - always had to add more fluid after startup.
Old Oct 27, 2004 | 08:05 AM
Jay's Avatar
Jay
That's what I was thinking. The "always in neutral" feel has for me been the TC not full causing it to go nowhere. But you buy from reputable shops so if there is a problem they've got your back. See what they have to say.
Old Oct 27, 2004 | 01:44 PM
mongooztt's Avatar
I was unaware you could add more fluid to the torque converter after its already in. Will fluid added to the tranny work its way into the torque convertor?
I would like to try everything else before I resort to talking to the shop.
Old Oct 27, 2004 | 02:35 PM
Mberglo's Avatar
1. Install tranny
2. Run car, shift tranny 10 minutes maybe.
3. Recheck and refill tranny. Fluid will make its way everywhere it needs to be, including TC.
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
